How do you remove the electrical lead from front brake lever?
  • Titbit21
    • Feb 2011
    • 76
    • Kent, Ohio
    I'm rebuilding the MC and need to remove this wire, whats the trick?
    '78E
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    If your like me you break it off, because it brittle and your in a hurry and then you order a new one from mikesxs.
    really though there are two little tabs that spring out and hold it in place. Its been a while but I think from the outside you'll see just two circular cut outs in the brake lever that you need to push in on to release it.
    1979 xs1100 Special -
    My Bike:
    [link is broken]
      Correct about the tabs.
        first I believe you need to pull the rubber cover back on the brake light switch (that is what this is). I've never been able to get to the top one, but if you look underneath at the 6-o'clock position, you will see the circular cutout, take a small tip screwdriver and push up on the tab at the foward end of it and gently pull out on the switch. It will come out easy when you get that tab pushed in correctly.
        • Titbit21
          • Feb 2011
          • 76
          • Kent, Ohio
          Thanks for the heads up. I will give this a try soon. Sounds like real fun, cant wait to test my nerves again.
          '78E
          • xs11lover
            • 1433
            • Montoursville Pa
            They just snap in, It sounds like you are on the right track. You push in or pull out on the outside of the housing. I just popped mine out the other day, It's not hard at all.
            79 XS11 Special (Lazarus)
            79 DT 100
            • ManitoulinLad
              • 358
              • Manitoulin Island,Ont.,Canada this is in Lake Huron
              Hey Psycoreefer - I know what exactly what you mean - Dan
              '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
              1179 big bore kit, 80SG motor
              Rebuilt head, valves
              TC Bros Forward Controls (Brass Pegs)
              Tkat Fork Brace
              T.C. Spade Fuse Box
              Dyna Coils & wires
              Mikesxs shocks,controls,& bars (special)
              ISO grips with stelleto ends
              4 into 1 black Bassani exhaust
              Bridgestone Spitfires
              Tuned by Tinman905
              & a will to keep it.
                • 3193
                On every 11 I have here the switch has but one button to push to remove it. Look on the under side where the switch goes in and you will see a hole. Inside that hole is a plastic tab that you have to push in to release the wires. The only one in my stable that has 2 tabs to release is the 81LH clutch switch for neutral lockout. I do not know if others are different but mine range from 78 to 82 and they all check out that way.
                • TADracer
                  • 1417
                  • Kenner, Louisiana USA
                  The switch will have two tabs but I am sure it only uses one tab and that is the one accessible from the hole on the underside of the MC.
                  BUT, having said that, it is good to have a spars since they get quite brittle.
                  Mike Giroir
                  79 XS-1100 Special
                  • Titbit21
                    • Feb 2011
                    • 76
                    • Kent, Ohio
                    Is there a thread on how to rebuild the front MC? I have mine off the bike and wish to start this, but i have never done this before and im already stuck on trying to pull this reservoir. I have read to gentle turn and pull (hasn't worked yet). I have the two bottom screws taken out, is there somthing im missing here?
                    '78E
                      Yeah, leave out the 'gentle' part. The early standard master cylinders seem to be much tighter than the later ones, and I had to put some muscle in to get mine off. It will help if you can get a thin edge (like a paint scraper) between the reservior and the main body and gently pry while you turn (OK, there is some 'gentle' involved!).
                      • SFerinTEXAS
                        • Jun 2006
                        • 877
                        I was thinking the same thing. Sorta like pulling carbs out with the stock airbox.No gentle way to do it. Just carefull.
                        79SF
                        XJ11
                        78E
