Ring Dilema
  • Edisto
    • Apr 2006
    • 60
    • Roanoke, Va
    Ring Dilema
    I replaced the lower end of my 78 Special with a used motor I picked up--the bearings on my old motor were shot. I just got my gasket set, cleaned and painted my heads, cleaned my pistons, etc. My rings look pretty worn. I would love to replace them, but at $50+ a set, I am not sure. The ring sets on Ebay seem to be more reasonable, but I am guessing these are oversized. Am I better off buying the more expensive standard rings, or going with the oversized set and lapping my cylinders?
    1979 XS1100 F
    1980 XS1100 Special--Frankenstein
    1982 XJ1100 Maxium x 2
    1980 Honda CB 900
    1981 Honda CB 900
    1981 Honda CB650x2
    2003 Honda 1300 VTX Retro-sold
  • clcorbin
    • Jan 2010
    • 495
    • Albuquerque, NM
    There is no way for anyone here to actually answer that question. We simply don't have enough information!
    The only to know what NEEDS to be done is to measure the cylinder bores with a bore gauge and compare it to the service limits in the service manual. If the bores are within limits for diameter and taper, then you can get away with a rering with standard size rings and a clean up hone.
    But if the bore is out of spec, you will need to bore the cylinders and go with larger piston and rings.
    It's possible it is just the rings that are worn (hopefully!), but you won't know until you take some careful measurements.
    -- Clint
    • windjammergump
      • Jan 2011
      • 71
      • shelby NC
      top end rebuild
      anyone know a good place to buy rings,and gasket sets for the top end..i am getting measurements tomorrow from machine shop what i actually have...just got the bike went thru carbs and tests for top end(head and valves are goood ) pistons and rings leaked down 14 on 1,2,4 and 40 on 3
      thanks in advance for any help GUMP
      windjammer gump
      bikes now own
      1981xs1100sh special
      1971 cb 350
      mini chopper project
      bikes use to own
      1978 750/four..
      1983kz1100 ltd
        Some of these fellas have been using the 1st. oversize sets from ebay and filing them down...
        http://cgi.ebay.com/ebaymotors/FOUR-...Q5fAccessories
          It is nearly impossible to find standard sized nos rings, and financially out of the question when found. Oversized rings are much easier to find and much cheaper and can be filed down to fit standard pistons (i wouldn't do this with anything other than 1st oversized though). Oversized pistons are even more difficult to find than standard sized rings.
          There is also the option of the wiesco big bore kit as well, not cheap either though.
            The other question is how many miles have YOU put on the engine since getting her on the road?
            Lots of them smoke and burn oil after sitting and after some time that clears up and compression comes up again.
