Of course I did not find the good instructions "Correct Procedure for Adjusting Clutch by Micah Hodges" until after I went crazy with the screw driver and now cannot disengage my clutch.
So my clutch lever was not as tight as it had been and I decided to adjust it according to the manual. I noticed that the adjustment at the lever was maxed out and knew that I'd need to order a new cable. I just wanted to get it working until the part came in so I decided to check the mechanical adjustment under the side cover. I backed off the locknut and adjusted the philips screw until I was satisfied that I had "touched the pressure plate" and came back off 1/4 turn, then tightened the locknut back. I started the bike on the centerstand and put it in first. Of course now the clutch lever has no resistance at all and the wheel is spinning like a mother.
Have any of you guys had to take the clutch cover off and adjust what the manual lovingly refers to as "the balls" to get this mechanism working again?
I'm hoping that it's just behind the cover and that I don't have to go messing around past the star nut and springs, etc.
I'd start by readjusting that screw. If your cable is that stretched, 1/4 turn may be to much. Try going an 1/8 of a turn instead.
