Pod question, yeah I know
  • #16
    I think your jetting is pretty close, especially since it will run without the filters. Sounds to me like your filters are too restrictive. I ran into this on a KZ900, albeit a slightly different filter. The filter simply would not flow enough air at WOT to keep it going. Changed air filter type and it worked fine.
    Possible causes are over-oiling the filter (if you used oil), blocked filter, too much media or the like. I run the same filters as you. I clean and oil them about twice a year, but they do not work well if over oiled.
    Again, if it runs without the pods, I agree with you that your jetting is fine. I would not change the jetting to compensate for this problem. Try cleaner or different filters first, and see what happens.
    Healthy is merely the slowest rate at which you can die
    Some people will tell you that slow is good - and it may be, on some days - but I am here to tell you that fast is better. I’ve always believed this, in spite of the trouble it’s caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba….Hunter S. Thompson
    • #17
      Mikes pods
      Originally posted by bigzack View Post
      - - - I ordered the Mike's XS pods tonight - - -
      Hi Zack,
      I have MikesXS pods on my XS11SG and (with the caveat that I ride like a fat old man) they don't seem to affect the performance any.
      What has happened is that one of my pods fell off in the street so be careful to super clean the carb and the pod lip on install.
      And on my son's XS750, the cutesy chrome cover with XS on it disappeared from one of them. OK, it can be salvaged
      (temporarily with duct tape, permanently with epoxy & sheet metal) but the hole will suck unfiltered air from when the cap falls off until you notice that it's gone and fix it.
      I'm not saying don't use them, they look great and work OK.
      Just take care on install and keep an eye on them afterwards, is all.
      BTW, pretty bike. I see you have discarded the front fender. The XS11 fork is too flexy even with the fender's bracing effect. I'd advise installing a Tkat fork brace to fix that.
      • #18
        Fork brace
        I am actually in the process of fabricating a fork brace. I didn't know anyone had one available. Do you have a link or something? I'll search this site in the meantime and see if I can find any more info on that. Thanks.
        1979 XS1100 Mac 4-2, Mikes XS Pods, 142.5 mains 42.5 pilots
        • #19
          This is the Tkat brace link
          http://www.tkat.com/forkbrace.html
          82 XJ1100
          Regina,Saskatchewan,
          Canada
          2006 V-Star 1100 custom
          • #20
            Very nice it looks very similar to the one Eagle Mike makes for the KLR650. Thanks for the link.
            • #21
              SH*T i just bought emgo pods for my 1980 xs11 ....Will i be blocking of any intakes on the newer style carbs?
              1980 XS standard With Pods and Harley mufflers
              • #22
                I know the 1980 carbs are a little different than the '79 models but from what I have seen I think they will. You can try changing the boots like I did and see if it helps you but I just don't think the Emgos flow enough air.
                • #23
                  Yes, all years get the same thing blocked, and both the early and late carbs have everything but the vent ports in pretty much the same places.
                  • #24
                    Update
                    Okay I got my Mike's XS pods installed today and took the bike out for a ride. Drum roll............. and I stil have the miss. Although it is much better than previously. I only get the miss if I hold it at WOT at 5000rpm when it starts to miss if I let off the throttle a little it powers right through. So now I'm thinking it is either float height, which I set at 25.5mm, or main jets which are 142.5. I think I will start with the float levels as they are easier to dial in than the mains. What are others running for float height? And what increments would I move them? If anyone has other ideas let 'em fly I'm open to suggestion. I did check the flow from each petcock and they are within a couple mls per min. so I think that should be close enough. I'm planning on replacing the plugs and doing some throttle chop tomorrow afternoon as I'm tied up in the morning.
                    • #25
                      hi bigzack,
                      that 5000rpm miss can be a little tricky, can either be the main jet (142.5 should be sweet tho with pod filters)
                      or the needle, from memory the needles are adj on the early
                      model carbs what have u got them set at?
                      with the floats heights ur slightly on the rich side, stock is 25.7, to see if there set correctly ride the bike in 5th gear at 2000rpm and then hit wot, the bike should pull nicely with out any lag or bogging down.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      1981 xs1100 RH (aus) (5N5)
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • #26
                        HERE is some great info on how to tune these carbs. What range each jet and part has the most effect on, and an order in which to proceed through selecting the right components.
                        • #27
                          forgot to add,
                          u should clean/replace the spark plugs
                          after each change if they looked to be fouled up.
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
                          • #28
                            Needle clip
                            Great point Pete. I wasn't even thinking about the needle. I'll try moving it down a notch IIRC it is in the middle notch. Thanks for the link DGXSER it looks like it's pointing to needle position too. This is all great stuff, learning lots. If I can keep from getting arrested for blasting down the backroads while I'm "test riding" and tuning it'll be great.
                            • #29
                              Update
                              So I moved the clip on the needle one position up, it was centered. That didn't fix the problem it actually moved the stumble down from 5000rpm to 4000rpm. So I moved the clip down to one position below centered. That moved the stumble back up to 5000rpm. I changed the plugs and checked them after moving the clip down. They look lean, white. So now I am confused because it runs really well sans filters, so that would lead me to believe it is rich with filters, but the plugs show lean? I think I will try putting the stock 137.5 jets in and see what difference that makes before I order larger Main jets. If that doesn't cure it I'll order some larger mains (145) and see if that helps.
                              • #30
                                Very nice the blue makes it faster. Blue 79s are the fastest...
                                Also my mikes pods have been on there for several years with no issues.
                                You should get the gold valve cartridge emulators 150 bucks well spent. I have mine looking like a cafe racer and after the emulators it handles luke one.
                                Also my stock jets were 140 mains with 210 airjet and 45 pilots. Some 79s came with those. You can find the info in the parts fische. No stumble with the pods. But now I am running zrx carbs
                                79 xs11 standard
                                8mm msd wires
                                tkat fork brace...
                                Fox shocks...
                                mikes650 front fender
                                led's gallore...
                                renthal bars
                                gold valve emulators
                                vmax tensioner
                                Rifle fairing
