brakes
  • radical123
    • Dec 2008
    • 172
    • salem or
    brakes
    Q:1 1980 special front and back brake disc, right side will they interchange? Q:2 will 1980 and 1979 special brakes interchange?
    1980 midnight xs1100 Rebilt cosmetically
    1980 midnight xs850 bagger
    1980 Special xs1100 (all apart)
    1979 special Special runner
    2011 street glide
    Front and rear do not interchange on the specials. The '79 and '89 special brakes will interchange for tge same position on the bike. Rear brake will interchange on any year/model XS11
      Why is that Nate? The bolt pattern is the same. and for the slotted disc it is the same for both right side disc. I am almost certain that any disc from any XS11 will bolt right up and work just fine in any position on any year or model XS11. In fact I am not so sure I see any issue with swapping right and left, save appearance, on the slotted rotors.
        [QUOTE=DGXSER;318574]Why is that Nate? The bolt pattern is the same. and for the slotted disc it is the same for both right side disc. I am almost certain that any disc from any XS11 will bolt right up and work just fine in any position on any year or model XS11. In fact I am not so sure I see any issue with swapping right and left, save appearance, on the slotted rotors.[/QUOTE
        Hi DGXSER,
        The fact that Yamaha clearly marks them L or R would make me reluctant to swap sides.
          I don't read carefully. I missed the word disc...pretty important part there....
          • Yahman
            • Mar 2008
            • 779
            • Salem, OR
            Hi Ron,
            The 79 and 80 Special both use the same caliper kits and brake pads up front, so I would think that they would interchange.
            Larry
            82 XJ1100
            80 XS1100G (Project bike)
            64 Yamaha YA-6
            77 Suzuki TS-185
              Hi rad,
              all XS11 brake disks and the front disks from a '77 or newer XS650 will swap between bikes and work OK.
              '80 XS11 Special disks are slotted so that they self-clean.
              FWIW, I reckon the brake pads can't tell which way the slots are raked so you can use a right slotted caliper on the left front and only your aesthetic sense will be bothered by doing so.
              The front brake calipers on '79 & '80 Specials are identical.
              Note that they are handed R & L and WON'T swap side to side.
