Airbox band clamps
    Airbox band clamps
    Do any of you know what size the band clamps are at the airbox carburetor junction? Mine are a bit trashed and I'm not home to measure them.
    The carb inlets are 54MM. Mikes should have what you need, BS34 carbs...
    http://www.mikesxs.net/products-40.html#products
      I knew you'd have the answer, Phil! I guess the 63-67mm clamps will do the trick.
        I measured one just now, 66MM fully open, 58MM fully closed. The OD of the air box boot itself measures 60MM in it's slot.
