James, the reason I tried one out, was that for one reason or another I could only get a very very very dim bulb on low beam, hi-beam was great, but low beam I could not see more than ten feet in front of the bike. Mind you, that does tell me there is a hornet in the wood pile somewhere that needed to be sorted, but I had worked on all the switches, replaced the RLU from my old bike that was in really good condition, and even swapped out headlamps. Still I could not get the low beam to work.
So, I saw this as a way to improve headlight performance, and cure my issue. When I first fitted it to the bike I took it out and I was astounded at how much light it puts out! It also had no problem giving me low beam and high beam. So this seamed like the cure.
With all the issues I have been having with this headlamp cutting out and coming back seemingly of its own volition, I decided it must be in the wiring harness somewhere, this bike sat in a field or barn for two or three years, and alot of the wiring is corroded under the insulation. So I swapped out the wiring harness from the other bike, a much more time consuming task than it would first seem, it is amazing how well strapped in that wiring is up around the head of the bike.
Afterwards, I can tell you three things. First, I am a gearhead and not a sparky!!
Second is that I have two bulbs with bad low beam!!
Third is that the HID light behavior issue is that one of the wires was getting tugged the way I had it installed and pulled a wire loose of its pin inside the connector.
So, today I will purchase a new regular bulb and see that it cures my issue with the stock headlight setup. After that, I may continue some experiments with the HID, as I also discovered I had the headlamp aimed pretty high, but honestly with the level of light that thing produces, I doubt aiming will cure that glare issue. But I like facts to be factual, not someone claiming their opinion as a fact.
Seems to be more than enough of that going around already, plenty in this thread alone.
And I learned a very long time ago when I had to take a course in statistics to get my diploma that anyone can take the same set of numbers and use some statistical equations and addin some colorful terminology and descritptions to make them show whatever it is they want it to show.
So at the end of the day, I would say I like the HID so far as light performance for my driving purposes. It seems to be providing a glaring light for the oncoming traffic, which I do feel is a bad thing for my future health, but how any person will react to any given set of circumstances is about as predictable as the next lottery numbers, making that strictly opinion. And those who have a weak charging system or poor connections often find that at idle speeds, the headlight dims badly to the point it can be dangerous to ride at night.
So there you have one persons opinions.
