brake parts needed
  • graybird78
    • Apr 2003
    • 360
    • council bluffs iowa
    brake parts needed
    i have 80sg in need of both front rotors& calipers. or rebuild kits for calipers. calipers are stuck. both rotors are warped. any suggestions on parts.
    when you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
    graybird78
    80 sg (old faithfull)
    Before you give up on the calipers, have you tried removing them form the bike, and puting plain bolt in the threaded hole for the banjo, then open the bleed screw, and put a greas gun on it, pump grease in there. Should push that piston out. May still be scrap due to bad corrosion, but at least you will know.
      The calipers can very likely be rebuilt; as long as the piston bore isn't seriously damaged or there's any broken bits, you can fix them. New reproduction pistons are available for about $25 each (stainless steel, so no more rust problems), rebuild kits are about the same per caliper. Most that you'll find used will probably need the same, so don't be quick to pitch yours..
      Rotors? You can get new ones from EBC, but at about $150 each definitely not a low budget choice. If yours aren't too bad, you can get them resurfaced here: http://www.site.truedisk.net/ ..but still not real lo-buck. Best bet is check the used market; good used rotors can be had for between $10-30 depending type and appearance. There's some trick light-weight rotors available for 650s that will fit XS11 'standards' (more $$$), but they won't go on your special forks/brakes.
      If your fronts are stuck, you better go through the whole system as it's likely to be gummed up elsewhere too...
      • mack
        • 2411
        • Ontario, Canada
        rotors
        I may have a spare set. I think these came off an 81 special. I bought them but found the tolerance below that required for the 79 sf. Find out what your tolerance is and I'll double check these. If Ok, we can stick a deal.
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
          I thought the brake rotors were completely interchangable for all models.
          • SFSPECBIKER79
            • Jul 2008
            • 403
            • NC
            rotors
            i know for sure they will on 79, 80 specials, i changed my 79 to slotted 80 spec rotors. i'm like you i think all the same at least from 80 back std, or special 1100's
            79 xs 1100 spec & 80 xs 1100 g
              Hi graybird,
              calipers off any year XS750/850/1100 Special will fit.
              Rotors off any XS11 and front rotors off a post '76 XS650 will fit.
              Note that only later model XS1100 rotors are slotted but unslotted rotors can be drilled.
              Or,
              check the parts for sale forum, especially Andreas Weiss' offerings, for a complete front fork off a Standard so you can get away from the Special's Weird Harold calipers.
              • mack
                • 2411
                • Ontario, Canada
                slotted
                Ya these are slotted, fronts anyway. Back is within tolerance. I know the front calipers are different on the 81's so I'm not sure if the thickness changed as well. These are straight and clean. But thickness is under what my manuals call for.
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                  Unless it is an 81 MNS, all the Special calipers are the same 79-81, including the 80 MNS. Of course they are different right hand to left hand though.
                    • 3193
                    Ok I have to ask instead of looking, but other than the color what is the difference?
                      The 81 MNS has the same brakes up front as the XJ, the linked system and differenet calipers than the other specials.
                        • 3193
                        I just looked and yes they do have different calipers. Whoodathunkit? Just have not got far enough in the 81LH fix to worry about brakes yet...lol. But it is coming soon.
                        • graybird78
                          • Apr 2003
                          • 360
                          thnx for all replys. ive had bike for 11yrs. money is very tight right now. better half not working. with gas prices now really need to get fixed.going to try to rebuild calipers. rotors are another problem. always flushed brake fluid every 2yrs as maint. always take very good care of bike. last summer had issues with front brakes. seemed if it sat for long periods , brakes would drag. rap on calipers would un stick them, would be fine as long as would ride every day. where i work we own brake shop. have tried in vane to get rotors turned. no one does bikes any more. I work as mechanic and have acess to brake shop, guy there unsure of mc rotors. really dont wont to buy from fleabayanyone have suggestions on where to buy good parts for calipers.
                          graybird78
                            Calipers probably just need to be pulled apart and CLEANED. Usually a sticky caliper is from gunk behind the square seal around the piston.
                            Pull pistons, remove square "O" ring, CLEAN the grove, clean "O" ring with brake fluid, and re-install. Problem will be fixed 95% of the time.
                            For rotors, you can use ANY XS11, XS650"late" rotor. should not be that hard. Just give Andreas a PM and see what he has.
