so I started to sync my carbs and didn't get far. i made a carb sync tool useing vinyl tubing and 2-stroke oil. Everything is conected together with Y's and T's with about 7 foot of tubing for each carb. when I started up the bike, it was pulling the oil in 1 and 2 so hard I had to kill the bike immediately so not to suck oil into the engine. Im guessing that the carb sides are way out of sync. I have to let the oil drain back down the tubing over nite anyway. I turned the middle adjustment clockwise a bit. It made the idle go up. So I turned the idle down and played with the middle adjustment a little. I am going to try to hook up the sync tool again after it drains. Question is when I turn the middle adjustment clockwise, is that starting to balance the sides? Im just trying to get it so I can hook up the sync tool without pulling oil in the engine. there is only about a foot of oil in each line in the bottom of the tubing. Maybe i need to take out a little oil also. What do you guys think?
