ok so my bike is running again Woo Hoo!!! and this is what I've done to get it here. I was having problems with it not staying running for more than 10 min because the charging system was (and still is) not working but also my battery was not holding a charge. so after chasing my tail on this problem I went ahead and bought a new Interstate battery $65 (the walmart neverstart batteries are not worth the $45 expense) ok so she's running and for the time being rideable. I just have to bring my trickle charger with me and plug her in while I'm at work.
What I am hoping y'all can help me with is I have to set the idle at 2k or the engine chuggs and dies. also until I get to above 3.5k and the engine is under load it chuggs and sputters, backfires a bit too.
any ideas what this could be?
I wen ahead and did away with the ICU and replaced it with 2 IGN modules from a GM truck as per the mod on the board here. this problem was present before and after the mod.
it did sit for about two months so that could be it. I did clean them last week, though I don't know if I did a good enough job. seems to run a tad bit better with the vacuum advance disconnected, not sure why
