My rear right turn signal stopped working. The front right turn signal stays on, not flashing. I swapped bulbs and found that all of them work.
The metal parts of the bulb socket are slightly corroded and I will thoroughly clean them.
Here comes the part that confuses me:
I checked the wiring and saw that the dark green wire is grounded with a "ring" to the stem of the turn signal. According to the the wiring diagram in my owner's manual the black wire should be grounded or did I misread this? What am I missing...?
Any help is appreciated!
Greetings from the Front Range,
Armin
Armin
