Hello,
Thanks to a lot of help by people on the forum I finally properly bled the front brake system and it works like a charm.
I have moved on to the rear brake system. I disassembled and cleaned the rear master cylinder and caliper.
Before connecting the rear mc to the brake line I filled it with brake fluid and and pumped the piston several times. Fluid came out of the exit port.
I then connected the rear mc to the brake line and screwed it into the frame and connected the rod which connects to the rear brake lever. I attempted the regular bleeding process using a mityvac. I cannot get fluid to leave the rear mc and enter the brake lines and caliper. I pushed the brake lever a bunch of times to see if anything would happen and nothing did.
I absolutely made sure the splooge hole was clean and besides fluid came out of the exit port when it was not connected to the brake line.
Any advice?
Adam
Any advice?
Adam
