number 3 running hotter.
  • OLY-XSer
    • Jun 2010
    • 46
    • Olympia, WA
    I haven't synced my cabs yet(just got done making a sync tool). I have been playing with pods and jets. I think im where I want to be. the bike is running great though. But when I check the temps on the pipes just below the first bend I noticed number 3 is running about 75-85 degrees hotter then the 1 and 2. number 4 is a maybe 30 degrees hotter then 1 and 2, but probably getting extra heat from 3. I have cleaned the carbs a few times. just did it again. But no change. Could syncing fix this, or is this a problem to worry about? where i checked 3 was at about 420 and 1 and 2 was running in the 330-340 or so.
    1980 xs11sg
    16600 miles, soon to be a lot more
    stock headers with free flow exhaust
    mikes xs pods
    #45 pilot jets
    #130 main jets on 2 & 3
    #125 main jets on 1 & 4
    Sync and colortune. The colortune (either with the tool, or by ear, or by Spark plug color) will likely be your solution. When the cylinder is running lean, it tends to be a little hotter. It's amazing what a difference those two adjustments can make in how well the engine performs.
      Don't think to hard till you have finished the setup.
      • OLY-XSer
        • Jun 2010
        • 46
        • Olympia, WA
        sounds good. I will sync the first dry day that I have off. So far this march its rained almost every day. thanks for the info guys.
        1980 xs11sg
        mikes xs pods
        #45 pilot jets
