Cam Timing Marks?
  • renegade_xs11g
    • 462
    • Mid-Michigan
    Cam Timing Marks?
    Well, i got the engine put back together last weekend....
    just started installing the cams....oops, I dont remember where the cam gear marks are supposed to go,
    If I assume correctly, the aim toward each other....is this correct?????
    Thanks, John
    My Photo Bucket
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    No.
    Set the crank on the "T" mark.
    The cams have dots on the shaft, and their corresponding journal caps have triangular marks. When all three indicators are lined up on their marks, you're timed.
    • renegade_xs11g
      • 462
      • Mid-Michigan
      Holy Taunting Timing Marks, Batman
      That could have been a disaster!!!!!
      THANKS!
      My Photo Bucket
      • DAVINCI
        • Jan 2011
        • 1048
        HOLD IT.
        You don't have a Service Manual?
        GET ONE. Doing the cams wrong will bend all of your valves.
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          Find one of Catatonicbug's posts and download the factory service manual from the link in his posts. There is also a clymer manual and owners manual available for download in there as well, well worth the time to download. I keep them on a thumb drive in my pocket just in case, in addition to the printed out copy in a 3 ring binder in the house.
          • renegade_xs11g
            • 462
            • Mid-Michigan
            Yeah, I do have a Clymers, souldnot find it in the darn thing
            My Photo Bucket
            • SFerinTEXAS
              • Jun 2006
              • 876
              Seems to me there is a bit of confusion here. Are you talking about the gears or the camshafts?
              If it is the gears I have a set of cams with the gears(cut the chain to remove) I can look at.
              79SF
              XJ11
              78E
              • petejw
                • 2269
                • sydney australia
                hey renegade,
                its from page 66 in the clymers, have a good read,
                as davinci said, it can be real easy to bend valves
                if it isnt done properly.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                1981 xs1100 RH (aus) (5N5)
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • renegade_xs11g
                  • 462
                  • Mid-Michigan
                  Thanks again for the info,
                  pete...page 66...guess I should have kept reading, lol
                  anyways, cams are in done correctly, THANKS....
                  now just gotta wait for shims, so, on to next thing.....
                  My Photo Bucket
