Hi all, was wondering if anyone knew of an easy way to lower my XS 1100. I am only 5'6" and can handle it with no problem, but would like just a little more leg control. Thanks:Rick
Lowering an XS 1100
Lowering an XS 1100
1980 XS 1100 replaced the seat and sissy bar from a XS 1100 standard and changed the handle bars. Did not like the original bars at all.No mod at all except for a four into one header.Tags: None -
Hey Rick what's the yr and model. Put it in your signature so it will be there for everyone to see .BDF Special
Dyno tuned to 98 hp at the rear wheel. -
Rick,
They are not all that hard to lower. Put on a set of handle bar risers and slide the front fork tubes up in the triple tree an inch or two. Install shorter shocks on the rear. They are available at Partsnmore, JC Whitney, and a few other places.
Keep in mind that lowering the bike will change the handling characteristics some and not all for the good. Then too you will start to scrape things in the corners as these bikes are a bit wide. The worst problem you will have with this project is that once the bike is lowered you will have to modify the kick stands to make it stand properly.The Old Tamer
_________________________
1979 XS1100SF (The Fire Dragon)
1982 650 Maxim (The Little Dragon)
another '82 650 Maxim (Parts Dragon)
1981 XS1100SH (The Black Dragon)
If there are more than three bolts holding it on there, it is most likely a very important part!Comment
Some people reshape and remove some seat foam to gain an inch or two.Nathan
Theodore RooseveltComment
I quit worrying about lowering mine. When i can afford another seat, or pan, i will lower the seat some. For now, i will just keep with one foot down at a stop. Being Height challenged is a problem with a lot of bikes. I tend to drag the foot pegs once in awhile, so i am sure that lowering it would spoil some fun.
__________________1980 XS1100LG Midnight
1991 Honda CBR1000F Hurricane
A cold beer and another one!Comment
1980 XS 1100 replaced the seat and sissy bar from a XS 1100 standard and changed the handle bars. Did not like the original bars at all.No mod at all except for a four into one header.Comment
Go to User CP and you can edit your "signature" . There you can post your yr and model or anything else you would like to tell us about your bike. If you look at the bottom of someones post you can see their "signature"BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
Modify the seat. You'll likely regret making suspension mods in the rear to lower bike.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
+1 on that. You can pick up almost two inches in the seat if you do it right. The trick is to don't cut the center foam too much, but to thin the outer edges for your thighs when your feet are down...Fast, Cheap, Reliable... Pick any two
Hey... leave out that word 'only'I've sold two XS1100 seats with cut down foam. They lower the height of the bike considerably and I saw another one on eBay the other day. One of my seats was about 4" lower, just by removing the foam. Plus, as others have mentioned, using shorter rear shocks and lowering the fork tubes. Yup, it'll affect the handling.... it might make it better!
XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Thinking about it....most experienced bikers have only one foot down when they stop their bikes. I can get both feet on the ground but rarely do. I just have my right foot on the ground and lean the bike slightly to the right. So, you don;t really need excess height to do that, eh? And, at least you won't look a bit like a grasshopper when you sit on the bike (like I do....)!XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
