Well now the the 81LH with the 79SF motor is starting and running good it was time to try some things out.
I made a short vid to show what the noise is and how bad it sounds.
You will see that I have it running, then I slip it into first gear and you will notice the rear wheel turn.
There is a dragging brake noise as well, but I have not gotten to the brakes as of yet.
I then switch it up to second gear, the rear wheel virtually stops turning and the noise is almost instant.
I then shift it down and back up but you get the idea.
The old second gear fix is upon me, I do believe.
The way it shifts I think there is a good possibility of a bent shifter fork as well.
If it were not for this site the old Hillbilly's bike would be in many parts by now.
My thanks to all who have helped me so far and those that will in the future.
For those that do not know click on the pic for the video.
Adn the dremel fix cost less than $50 to do.
