Leak in exhaust joints
  • patk12345
    • 96
    • Chicago, IL
    Hey folks,
    Just re-installed my exhaust system after the dremel fix and I appear to have a leak at the joint were the the #2 pipe meets the muffler assembly. It seems well seated, and the clamps are tight. Am I missing something obvious? Are there any tricks to getting a better seal at those joints? If I can't get a good seal are there any cheats e.g. welding the joint, or JB Weld? I'd rather do it right, but if I can't get a seal the right way, I'll take what I can get.
    Thanks in advance.
    Pat
    Pat K
    80 XS11 "Special" Standard
    (80G chassis & engine w/ 79 SG lights and cluster)
    79 XS650 (engine currently squeals like a stuck pig.)
    72 Plymouth Satellite (met an unpaved manhole collar, which it managed to tear out of the street, currently has some "issues")
    04 Current Designs Solstice GT XL Kayak (I like it because it doesn't have carbs, or any other moving parts)
  • ManagerMike
    • Mar 2010
    • 445
    • S.E. Michigan
    A paste product available at most auto parts outlets called 'muffler weld'. It comes in a small tin, has the consistancy of watery pla-doh and is ideally suited for sealing exhaust system joints.
    It will work best if you disconnect the joints, apply the product then reassemble. It will dry, however heat will cure it, if there remain any small leaks, you can simply apply more to the leak and let it dry, just wear latex gloves when you use this stuff, it likes to stay on your skin a long time.
    '78 E "Stormbringer"
      • 5069
      Originally posted by patk12345
      Hey folks,
      Thanks in advance.
      Pat
      I don't know much about specials, but there is a kind of "sleeve gasket" for the standards that is repacable.
      • SFerinTEXAS
        • Jun 2006
        • 877
        Before PartsnMore redid their website, they sold exhaust sleeve seals for the xj11. My research says they fit all XS pipes. Maybe contact them and ask if they are still available.
        79SF
        XJ11
        78E
          Should still be able to get from a local dealer also. All three are the same, 3JJ-14653-00 is the part number I got off one I have.
          • Shacknasty
            • Feb 2011
            • 379
            • SFV-SoCal
            For exhaust sealing (if the sleeves don't do the trick or ya can't find 'em and wanna ride!) a good product is Ultra Copper by Permatex. It remains flexible and does't harden. This is a good thing when yer talking about motorsickles that bump and vibrate. Plus it makes it easy to remove and reinstall yer exhaust. I usually put a smear on the exhaust gaskets too.
            • James England
              • 3039
              • North of England
              An exhaust maker I know of recommended normal bathroom silicone sealer! I used it on my bike and it's fine......
                Silicone is corrosive to steel.
                • James England
                  • 3039
                  • North of England
                  Mmm.... so's nitric acid..... the stuff that comes out in the exhaust fumes!
                    But your exhaust is stainless so neither really matter for you. But why apply something corrosive when a different non corrosive product works just as well or better.
                      Silicone itself is corrosive to steel. I think you will find that the composite they sell as caulk has some inhibitors in it to keep it from corroding the steel though. Kind of like antifreeze in your car, water is very corrosive to all metals, but they add inhibitors to protect steel and aluminum into the antifreeze.
                        Most silicone caulks I have looked at do specify not to use on bare steel.
                        • James England
                          • 3039
                          • North of England
                          True, my system is stainless. Mind you, having said that... after getting my stainless system made, and posting photos here.... I just sold it on eBay! Call me an XS1100 NERD but, there was no bevel at the end of the silencers as there should be on the UK E and F models. It began to irritate me instensely.... completely unreasonably too, I suppose. I did ask the person who made it to make sure he put the bevels on but he had flu and was ill when he made the system and he.... forgot!
                          I just took delivery of one of the stainless steel replica systems supplied by an eBay seller in Germany. It arrived 3 days after I ordered it and really is a substantial and well-made system. With bevels. I'm waiting for two OEM used silencer mounting brackets from the USA. As soon as I get them, I'll get the system on and post some more pix.
                            Back to the original issue of leaking exhaust. Other than replacing the doughnut inserts as they do get more compressed over the years another quick-fix would be to dremal cut the clamp stops which will allow the clamp to be pulled together a bit farther. Have made this work untill I got new inserts.
                            • James England
                              • 3039
                              • North of England
                              I seem to remember using strips of Coke can with exhaust paste on them at the exhaust joints......
