Front caliper removal
  • Stuckinmud15
    • Feb 2011
    • 64
    • Cheektowaga, NY
    Might be an idiotic question, but I am trying to remove the front calipers to clean them out, and they will not come off. Am I missing something here? I removed the nut from the "stud?" that holds eack one on to the forks, and the calipers are wiggling real good, but will not pull off. tips? tricks? Thanks!!
    2007 Yamaha r6
    81SH
    That stud is actually a bolt that goes all the way thru the caliper from the bottom. Take off the plastic cap and you'll see a 12MM bolt head, take it out.
    • subike
      • 167
      • Christchurch New Zealand
      dont you also have to remove the locking screw for the brake pads?
      The one you access from the back of the caliper?
      http://i139.photobucket.com/albums/q...e/DSC00009.jpg
      1980 XS1100 Std English Assembled, 378k miles
      In stock untouched contion.
      http://i139.photobucket.com/albums/q...e/seatside.jpg
      1979 XS1100F Std NZ new,
      Mikes XS coils
      Jardine 4-1
      Pod filters
      Harley Davidson Rear Fender
      Bullet signal lights
      Twin 75mm headlights
      Self made single seat
        These are the Special calipers, no locking screw.... one bolt and they're off.
