Triple Tree/Headlight Ear?
  • Filter
  • Triple Tree/Headlight Ear?
    I was going to put the forks on this morning before work and went to put the special headlight ears (putting a special headlight on a standard) in and found that they don't fit. The tube that the forks slide through is about a half inch linger on these ears than the standard ears that were on it.
    So my question is, is the distance between the upper and lower triple tree different between the standard and the specials?
  • #2
    Yep, they are... another one of those little surprises you find when swapping parts.
    • #3
      No one has ever said anything about that, or at least that I have read. I have always seen people sat that the headlight swap was just a straight up parts swap. Interesting...
      • #4
        Originally posted by natemoen View Post
        - - - my question is, is the distance between the upper and lower triple tree different between the standard and the specials?
        Hi Nate,
        sure is.
        Standard upper 'tree dekes down while the Special upper 'tree goes straight across.
        No biggie to fix it, crop ~1/2" off the Special headlight ear tubes with a hacksaw.
        • #5
          I suspect the reason for this is when they installed the shorter 16" rear tire on the special (lowering the rear of the bike a bit), the special tree design lowers the front to match.
          • #6
            Nate
            Mine were like that when i got it apart to put the correct triple tree on. I do have the set of black ones that are cut. They are yours if you want them. Also keep in mind that the front name plate may be different mounting as mine was. I had to get a new one of those as well. The Special, and Standard lower tree bolts on different.
            1980 XS1100LG Midnight
            1991 Honda CBR1000F Hurricane
            A cold beer and another one!
            • #7
              Originally posted by XS1100 Newbie View Post
              - - - Also keep in mind that the front name plate may be different mounting as mine was. I had to get a new one of those as well. The Special, and Standard lower tree bolts on different.
              Hi Newbie,
              yeah, amazing how those little details slip one's mind, eh?
              You gotta take the tinsnips to the Special's chromething so it'll fit the Standard's lower tree because they moved the clamping bolts.
              WTF they do that, eh? Dumbfux!
              I later had to reduce the chromething into individual cups in order to install the WER steering damper.
              • #8
                The next question is, is it better to cut the extra off the top or the bottom of the ears?
