'80 Special taillight mount
    Ok, I've looked at the parts fiche and in the FSM, and I'll be dipped if I can figure out how the taillight is supposed to mount, or to what. There looks like there should be some sort of intermediate bracket between the taillight and ???, but I can't find a pic anywhere.
    I'm trying to resurrect the SG I originally bought for parts, and the original grab rail is gone if that's what it attached to. The PO had the light 'farmer-installed' to the luggage rack/trunk mount (and that wasn't for this bike either). So, can anybody help me out with a pic of what it's supposed to look like?
    If I at least knew that, I could come up with something...
  • petejw
    • 2269
    • sydney australia
    is the 80 model where the tail lite
    mounts behind the seat or on the guard?
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
      Pete, the taillight is mounted 'inside' the grab rail and semi-tucked under the seat as near as I can tell. The plate mounts separately at the tip of the fender and has it's own light.
      • petejw
        • 2269
        • sydney australia
        no worries steve,
        i dont have that model, if it was attached
        to the guard i couldve taken a pic for u.
        i do remember seeing a pic that had some sort
        of plate attached to the seat that the tail light mounted too,
        i know not much help hey.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • petejw
          • 2269
          • sydney australia
          lol
          wrong again,
          it attaches to the grab rail,
          heres a pic i found
          does that help?
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • MrOzz
            • Aug 2008
            • 782
            • Massachusetts
            Here is the pic of the tail light mount.
            Hope it helps.
            Ozz
            1980 XS 1100SG
            Dyna 3 Ohm Hi Output Coils
            Pod Filters
            DynoJet Kit
            T.C.'s Fuse Block
            V-Max Auto CCT
              Yep Ozz has you there, the tail light itself mounts to a plastic bracket. The bracket mounts to the stock grab rail.
                Thanks Ozz... that's what I was looking for. Of course, I don't have any of those parts (other than the tallight), but that at least gives me an idea.
                Looks like I'll need some sort of 'finish' panel to cover the gaps...
                • trdriver71
                  • 360
                  • Edmonton Alberta
                  you could just buy a light of ebay like this one that appears to the that panel.
                  http://cgi.ebay.ca/1980-XS1100-TAIL-...#ht_1056wt_905
                  or you could just buy the bracket...
                  http://cgi.ebay.ca/80-YAMAHA-XS1100-...#ht_1495wt_905
                  '79 XS11SF
                    That first one is not a bad price. I've bought off that seller before as a good experience.
                    That bracket alone though is VERY high price!!
                    If Steve does not buy the grab bar, that bracket is not going to be very helpful.
                      Yeah, I've pretty much ruled out getting a grab bar as I know how hard those are to find ($$). This project bike is the 'don't spend money I don't absolutely have to' type, so if I can make something, that's what I'll do.
                      I've also got a '81H seat (no cutaway for the light), so I might just use a standard taillight assembly instead.
                      • XS1100 Newbie
                        • Jun 2009
                        • 1106
                        • Battle Ground, Washington
                        If this bike is going to have a rear fender on it, why not use the mount off of like a 1980 standard that mounts to the fender?
                        1980 XS1100LG Midnight
                        1991 Honda CBR1000F Hurricane
                        A cold beer and another one!
                          Like so many things on these bikes, 'it's not quite the same...'
                          I am looking at that; but the fenders mount differently, and if I drill holes for the light there's no reinforcement in the special fender (plus I end up with leftover holes). I'll figure something out....
                          • tom clisham
                            • Sep 2010
                            • 627
                            • Northern Illinois
                            Steve: I've got al luggage rack & trunk on my 80 SG. I had to leave the original bracket off to fit on the luggage rack. I attached the tail lite to the sissy bar with a couple of pipe clamps from home depot.
                            Good Luck
                            Tom Clisham
                            Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
                            _____________________________________________
                            '78xs1100E ,all stock & original GONE TO WISCONSIN
                            '80 SG Vetter fairing,hard bags,trunk,fork brace,
                            stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
                            79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
                            79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
                              - - - I'm trying to resurrect the SG I originally bought for parts, and the original grab rail is gone if that's what it attached to. - - -
                              Hi Steve,
                              like they said, the SG's tombstone tail light bolts to a plastic adapter which bolts to the cast aluminum grabrail.
                              petejw' link to furious4's ad in the parts for sale forum says (in part) "Grab bar with working tailight assembly. painted black with basecoat-clearcoat system ( no rattle can) $40.00"
                              That ad is dated 09-16-2010 but if he's still got it, for $40 you are golden.
