I am planning on ordering one today, but wanted to get some feedback from anyone familiar with them. First off, what size plugs do our bikes run? Also, do I need to order the 4 plug colortune, or will a single one work?
Morgan Carbtune and Colortune info (plug size, etc.)
1980 XS1100G. Work in progress.
1980 XS1100G. 2nd work in progress.Tags: None -
Our bikes use the 14mm. As to the colortune, you only adjust one at a time, so the single will work. You do need to turn the engine off, remove it from one cylinder, and install in the next between tuning each cylinder.
It would certainly speed up the process with 4 of them. Well ...Maybe...Every bike I have ever had one on, even when tuned correctly still misses and pops periodically on the colortune plug. It is a great way to see inside the chamber while the bike is running and adjust mixture to prety dang close. But it does not spark 100% the same as a real spark plug. This is why you still need to read the plugs and make any needed final small adjustments after colortuning (IMO anyway....YMMV...and all that stuff)
78 XS750 -
We use 14mm plugs. The 4-port carbtune is the way to go. You CAN get away with it using the 2-port, but it's a lot easier to plug in 4 tubes and take care of it all at once than have to keep switching back and forth.1980 XS850SG - Sold
-H. FordComment
Thanks for the reply. Do you think maybe I should just forget about the Colortune, and just go for the Carbtune? It's quite expensive for both.1980 XS1100G. Work in progress.
1980 XS1100G. 2nd work in progress.Comment
If you can only swing the cost of one, get the Carbtune. It's compact, clean, simple and easy to use. The colortune is nice, but some people have a definite distaste for them. The task that they perform can be done by ear (if you know what to listen for), or by checking the plugs over time. If you can swing the cost for both, I would suggest getting both.
Oh, and make sure you get the storage case for the Carbtune.1980 XS850SG - Sold
-H. FordComment
The Colortune is more expensive than the Carbtune, and if I got both, with the case, it is $247 and change which doesn't include shipping. That's a little much right now. The Carbtune is $100 + shipping. I think I'll stick to that, and try to deal with getting the fuel adjustments right based upon plug color, etc.1980 XS1100G. Work in progress.
Misread I guess, I thought you were debating getting 4 colortune plugs. Did not know they made a single cylinder carbtune, for that I would stick with my mity-vac and a PVC plenum.
I agree completely that if your going to buy one or the other, the carbtune will save you much more time and effort than the colortune plug.Life is what happens while your planning everything else!
78 XS750Comment
Thanks for the info, guys. I only ordered the Carbtune.
PS- It comes with 5mm and 6mm adapters. I am assuming this is all I need?Last edited by ThrottleJunky; 03-09-2011, 02:15 PM.1980 XS1100G. Work in progress.
I really like the Carbtune. Good quality, well-made and useful tool that does it's job. No mercury is one of the many features...Comment
Colortune plug
Does anyone have a broke or junk one they could send me? I was talking to some guys at work about one and they said what the f--- are you talking about, they said never heard of such a thing. I wanted to show them what it look like. Better to show the real thing than to look at a picture.Thanks Tom
82 XJ DAILY RIDE
78 XS1100E FIXING UP
79 XS1100F PARTS BIKE
79 XS1100SF NAKED BIKE
80 XS1100SG FULL DRESS BIKE
82 XJ IN THE ROUGHComment
Ordered on the 9th, and still no sign of this thing. Starting to become impatient.1980 XS1100G. Work in progress.
That's certainly the longest I have ever heard it take. mine was pretty fast to arrive. have you tried contacting them?Nathan
Theodore RooseveltComment
Mine took a week or two at most.Nathan
I've been thinking about getting one myself. For those who have ordered one, is there an import duty or tax or whatever?XS1100SG - Obsession
Like I told my last wife, I says, "Honey, I never drive faster than I can see. Besides that, it's all in the reflexes."
-- Jack BurtonComment
