Understanding a flasher problem
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    My flashers work most of the time.
    At idle the flashers will often stop working. A blip of the throttle will get it working.
    As I understand the resistance of the circuit will cause the flasher coil field to collapse and reestablish opening and closing the contacts.
    How does raising the idle thus raising the voltage cause the flasher to work?
    Thanks in advance
    Rick
    650SF
    XS1100SG Project bike
    Looks like U answered your own question........
      • 7829
      As motoman said, when you "blip" the throttle, you increase the output of the alt, and the voltage goes up, and the flasher now works!
      A fix is the clean EVERY SINGLE CONNECTION on the bike! Pay special attention to the ground between the battery and the frame/engine. Put antisieze (sp?) on ALL grounds! Use dielectric grease on all "hot" or positive connections. Don't forget the battery post themselves!
        Rick, there is a standard two-wire connection with a bimetallic contact arm in the flasher that heats and cools to make and break the flasher circuit.
        Not enough voltage = not enough heat to make the arm break the circuit so the lights flash slower and then 'hang' on.
        Rev the engine and the voltage goes up, the arm heats up and breaks the circuit and the flasher starts working again. Like Ray said, clean the contacts in your wiring harness and you should be able to get the flasher to work even when the engine is not running.
        There is also third wire in the stock Yamaha flasher that goes to a giant capacitor molded into the end of the flasher body, that's why the flasher unit is so honkin' huge. It works with the factory self-cancelling circuit and it's not usually a problem.
        • Rickrod3
          • Jun 2009
          • 721
          Okay thanks guys.
          I'll keep up the KP. duty on the wiring harness.
          Rick
          650SF
          • bobber
            • Dec 2008
            • 82
            • los olivos. ca
            flashers or indicaters as we say
            you could put an electronic flasher relay onit .they work good.no auto cancel with them.
            1978e. special forks.she's a frankinstien.a bit of this a bit of that.its a monster
            • Rickrod3
              • Jun 2009
              • 721
              Trying to keep the auto cancel. Thanks tho. They work 99 percent of the time just don't want to have to blip the throttle to have them flash while pressing the brake stopped at a light.
              I have cleaned a few connectors and it seems better so, I'll keep cleaning.
              I also am waiting on some led tail and brake lights which should help.
              Thanks
              Rick
              650SF
                • 8930
                Rick, after making sure all your connectors and grounds are clean, the last resort is to take the cover off the factory flasher unit and file the "points" on the relay with an emery board or fine sandpaper. You will probably find that they are pitted. HTH
                • cywelchjr
                  XS-XJ Super Guru(Deceased)
                  • 4450
                  • Sacramento, CA
                  Thanks
                  Rick
                  Change out the brake lights to LEDs, and that may well solve that problem. You can pick up the 1157 type red LED lights at Auto Zone or the like and they are a direct plug in replacement. No more dimming of the headlight when the brake light comes on. And that's even with the extra 4 lights of the vetter trunk on mine.
                  • Rickrod3
                    • Jun 2009
                    • 721
                    Hey CY:
                    I'm waiting on these.
                    Super Bright LEDs is one of the largest online retailers of LED lighting for commercial and residential uses. Enjoy free/same-day shipping on qualifying orders!
                    I'm thinking it will do the trick.
                    Rick
                    650SF
                    • Rickrod3
                      • Jun 2009
                      • 721
                      I replaced the two tail light/stop light bulbs with the led type.
                      It solved the problem.
                      Still going to continue to replace terminals in the connectors to ensure reliability.
                      Any how thought I'd let you guy's know how it turned out and thanks for your input.
                      Rick
                      650SF
                        Good work Rick. Yep, keep cleaning anyway. You never know which connection will be the one that causes the next gremlin. So while the riding weather is still hit or miss at best, spend some quality time with your ride.
                        • Rickrod3
                          • Jun 2009
                          • 721
                          Will do Don.
                          Bike is running good I take many rides in the 70 mile range took a trip to lake George 180 miles planning on XS north trip to Va. around 400 miles.
                          Trying to make sure it is reliable as possible.
                          Rick
                          650SF
