Fuel Line Protection?
  • CatatonicBug
    • 6117
    • Clinton, UT
    I have replaced my fuel lines with Tygon tubing, and I really like how flexible it is. Unfortunately, after about a year, the tubing has become HARD! I bought some 90ยบ inline filters from Cycle Gear to add to my fuel lines, but the lines are too stiff to trust adding the filters to them. I'll have to replace them again, at over $2.30/ft., and would really like to protect them from getting stiff again.
    The way I understand it, the cause of the hardening of the lines is UV exposure. I'm trying to come up with a reasonably cost-effective way of preventing UV exposure, but retaining the flexibility of the Tygon. I found some stuff called Nylon multifilament sleeving that seems like it might work, but I'm not sure. Has anyone else found a solution to this problem?
    I know there is the option of braided stainless lines, but with the octy and inline filters, the cost of the end fittings really gets astronomical, and I'm not sure if there's even enough room for them around the octy. I'm sure the flexibility isn't all that great either.
    • 7794
    Just replace the lines one time with filters, and your good for two years, tops. Tygon has it good and bad sides. The cost per foot isn't that bad, when you look at the cost of BAD fuel lines! I've found a good local supply of fuel lines, and they seem to last about three years. In this day, that's a LONG TIME!
    • CatatonicBug
      • 6117
      • Clinton, UT
      I figure that if a cage can keep it\'s fuel lines for the life of the vehicle, I shouldn\'t have to change them every year or two. If I can prevent them from deteriorating, it might save me the $20/year I\'ve spent on fuel lines.
      • Iron Duke
        • Jun 2010
        • 74
        • Manhattan,Ks
        Gas line
        Hey Bug,How ya doing,
        I don't have the hardening problem with my Tygon , but have had a problem with it tearing on the wall pulling it off the petcock outlet, I'm using Tygon on both the gas line and the smaller air inlet side,price isn't all that bad and way I got it figured out once a year new filters/new line,all for about ten dollars. Part of my yearly maint.
          Couple times a day you could rub sunscreen on the fuel lines.....
            Hey Bug,
            A cheaper option that I find works just as good and just as flexible is Lawn mower fuel line. Go to your local hardware store in the yard care section. You can by several feet of it for $2-3.
            • Redshirt
              • Feb 2011
              • 142
              • Titusville, Fla.
              I dont know if Tygon is clear/tanslucent or if that is a factor you want to retain, but I bought Performix brand Plastidip multipurpose Rubber Coating spray for my carb boots and recoated them giving them new life. For your applications it should shield well against UV.
              This applies in very thin layers and is very flexible. For the carb boots I applied it 4 times to keep the cracks from getting worse and look more presentable.
              The sprays come in a few colors and clear, but I went with black.
              I bought mine at Ace Hardware but this is their URL http://www.usplastic.com/catalog/ite...2872&catid=699
              good luck!
              79 Special
              2012 FJR1300
              78 E (project. Clutch problems from PO) Must sell
                Tygon is a yellow transparent line. I personally wouldn't.want to coat it and not be able to see through it.
                • CatatonicBug
                  • 6117
                  • Clinton, UT
                  Originally posted by Iron Duke
                  ...way I got it figured out once a year new filters/new line,all for about ten dollars. Part of my yearly maint.
                  That's just it... I shouldn't HAVE TO replace my fuel lines every year if a cage can keep the lines for decades. There is no difference between the fuel that is used in the two vehicles, so I figure there has to be something that can be done to keep the lines from deteriorating on the bike.
                  cute... My bike would end up smelling "tropical fresh" at the same time!
                    A cage uses different type of fuel line plus they are always concealed and in the shade. That thick double walled stuff will stay soft for a long time....
                    Or take your pick of the tropical scents
                    • DAVINCI
                      • Jan 2011
                      • 1048
                      • Cedar Mountain, NC
                      Bug;
                      McMaster-Carr sells it for $1.25 per foot. THEIR PART # 5552K24, get 50 feet or more and it's $1.05 / ft.
                      McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
                        Any reason cheap heat-shrink tube wouldn't work as a cover? It's flexible, opaque (even in colors), and easy to find...
                        • XS1100 Newbie
                          • Jun 2009
                          • 1106
                          • Battle Ground, Washington
                          I was looking the other day, and saw where there was a black Tygon line. Maybe they were not telling the truth, but it did say it was available in black. Black in itself should help protect the line. If the sun can't penetrate in, then it can't do as much damage. It is like using white caulk instead pf clear. The sun goes through the clear, and bakes it off from underneath, but the white does not have the problem.
                          1980 XS1100LG Midnight
                          1991 Honda CBR1000F Hurricane
                          A cold beer and another one!
                            Bug, most fuel line in a car is metal, like the brake lines. It only goes to rubber just when it is connecting to the carb/ throttle body. Most newer cars are hard piped from what I have seen. What is under the hood is not subjected to UV or much of the weather. Its kind of like thinking your seat could be made of crush velour and stand the test of time same as in my 84 olds. Nice as it sounds, just not going to happen.
                            I will say, a local independent bike shop sells black fuel line for bikes at about $2 a foot IIRC. That was when I decided to use Briggs and Stratten fuel line. If it holds up in my mower, it should do fine on the bike.
                            • CatatonicBug
                              • 6117
                              • Clinton, UT
                              That was one thought I had. I have a hard time finding it in any decent quantities around here though. All I ever get is the little assortment pack at Radio Shack. I have a small spool of red stuff too, but it's way too small for the fuel line to fit into.
                              My mower uses the black stuff too. However, my mower only sees sunlight maybe 3-4 days/month for about 2 hours, and none at all in the Winter. My bike sees sunlight every single day of the year, all day long (I park in a semi-exposed carport, and ride year-round). I can't really compare my bike's UV exposure to a mower's.
