Been working on the carbs for the 79F and ran into some confusion about the shaft seals. There were 2 sets of carbs with the new bike. One set had the seals installed with the groove in the seal pointing out, and the other had the groove pointing toward the center of the carbs. So ,for the definitive answer, which is the correct way to install the seals, groove facing in or out?
Throttle Butterfly Shaft Seals
1979XS1100SF
K&N's and drilled airbox
Jardine 4in1
Dunlop Elite 3's
JBM slide diaphragms
142.5 main jets
45 pilot jets
T.C.'s fusebox & SOFA
750/850 FD mod.
XV 920 Needle Mod.
Venture Cam Chain TensionerTags: None -
hi tim,
the seals point outwards, this stops the air from being
sucked in thru the shaft.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url] -
carb seals
Thank you Pete.1979XS1100SF
Jardine 4in1
Dunlop Elite 3's
142.5 main jets
45 pilot jets
750/850 FD mod.
XV 920 Needle Mod.
Venture Cam Chain TensionerComment
