This wire
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    DGXSR & Bug;
    That wire is part of the starter motor lead, so I'm guessing he used the one from the '78 motor.
      • 3193
      While I was not the one who did the motor swap DAVNICI is right. I took the side cover off my 79SF that was in storage and it is the same. The wiring diagram was of some use, but the 81 MNS seems to have some of it's own peculiarities. The wire I was asking about was from the starter from the 79 SF the motor was from. I do not have the dead motor from the 81 as TC suggested so I can not transplant the pick up assembly. The starter works fine now as I found a dirty connection under the tank that was the fault. It seems to run fairly good and now I need to reset the carbs synch etc to get it right. I thank you all for the advice and will be back with more questions...TRUST ME on that.
      • rockman
        • 23
        • Inverell NSW Australia
        My 1980 1100G has the yellow/red wire from the TPI taped off. Am I reading here that it isnt necessary so I should leave it alone? Bike runs without it. Answer is obvious I suppose.
        • ManitoulinLad
          • 358
          • Manitoulin Island,Ont.,Canada this is in Lake Huron
          Ditto on the green wire
          I have an 80SG motor in my MNS & the same green wire was sitting in limbo. I cut it short & sealed it off - all works fine. This is the 1st time someone brought it up though - I always wondered about that, now we all know - what a site - Dan
          '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
          1179 big bore kit, 80SG motor
          Rebuilt head, valves
          TC Bros Forward Controls (Brass Pegs)
          Tkat Fork Brace
          T.C. Spade Fuse Box
          Dyna Coils & wires
          Mikesxs shocks,controls,& bars (special)
          ISO grips with stelleto ends
          4 into 1 black Bassani exhaust
          Bridgestone Spitfires
          Tuned by Tinman905
          & a will to keep it.
