Hi all!
I'm in the process of rebuilding the carbs on my 80G.
PO stripped the slots on the idle mix screws by using the wrong sized tooling.
I just picked up an "EZ out" kit, and drill bits...
I have the new screws to reference for size...
My plan is to take a large bit the same size as the head of the screw--and to make a good, clean center mark on the heads (without getting into the aluminum of course)... and then to use that center to start the pilot hole for an "EZ out," let them cool after drilling, soak with Kroil, and give it a go at backing those puppies out.
Does anyone have experience in doing this?
Any helpful tips, or links I should check out?
--I did a search for about 15 minutes, and I think I was too specific in my wording?--
THANKS IN ADVANCE!!!!
