Repairing Fuel Sending Unit (question)
  • Redshirt
    • Feb 2011
    • 142
    • Titusville, Fla.
    I just pulled my fuel sensor/sending unit off to turn it around (shop put it on backwards). As I have with everything Ive touched, I figured Id give it a quick brush off to clean it and... snap... I broke the small wire from the plate side (inside-facing thin wire from sensor to disk riser on base of plate).
    Is it okay to solder it back on?
    Also, should there be a gasket covering that portion (where the soldered piece is down to the plate)? It will be inside the tank and I dont know if it originally had one.
    The sensor and its riser are fine, just the wire at the base of the plate has the wire popped off.
    79 Special
    2012 FJR1300
    78 E (project. Clutch problems from PO) Must sell
