Carb diaphragms
  • Aches n Pains
    • 349
    • Reston, Va.
    Carb diaphragms
    Got two sets of carbs with my recent purchase. Am in the process of cleaning them and was curious if anyone has any suggestions re: cleaning up the diaphragms. They seem to be in pretty good shape but I want to "lube" them a little to keep them from getting brittle.
    Appreciate the great help I get from this forum.
    1995 KZ100P
    Pods, jets, pipes, cam adjuster, oil cooler
    1977 Ironhead - custom build
    Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
    Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
    Could rub them down with vasaline.
    • 81xsproject
      • 3185
      • Fortuna, CA
      I use spray silicon on them. I seams to work very well and returns some flexibility.
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • Redshirt
        • Feb 2011
        • 142
        • Titusville, Fla.
        Ive read around here not to put anything on them.
        I imagine hot, soapy water would work, but be careful to dry it well. I used alcohol on a paper towel and very lightly rubbed them clean, but that probably wasnt the best thing to do.
        79 Special
        2012 FJR1300
        78 E (project. Clutch problems from PO) Must sell
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          No, alcohol is not good for rubber. I would recommend the silicon spray, as that stuff will often revitalize the rubber somewhat. I used to get stuff that we used on the rubber rollers of printers that was called "rubber revitalizer" that removed ink and dirt and paper crap from the rubber and made it nice and soft and sticky again (not tacky, just so it would properly grip the paper like when new), but I haven't seen that stuff in years.
          • TADracer
            • 1417
            • Kenner, Louisiana USA
            Baby powder
            I have been putting baby powder on mine for years and they are original and still like new. I picked this tip up from the manual that I had with an old MGB my wife used to drive.
            MGB, now talk about a piece of engineering C$@p!
            Mike Giroir
            79 XS-1100 Special
            • mxmikie
              • Aug 2008
              • 482
              • Bouse az
              ky jelly works great
