Valve Shim Starting Point
  • SFerinTEXAS
    • Jun 2006
    • 876
    I have an engine I robbed the shims out of some years ago and want to try to use. Thinking of the best way for a starting guess on which shims to try.
    Thinking off hand maybe a straight edge laid in the cam journals And try a slide mic to measure to the bucket tops and subtract the lift specs.
    Anyone know a better way?
    79SF
    XJ11
    78E
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    You could just pop eight shims in, measure, then change.
    Less math.
    • SFerinTEXAS
      • Jun 2006
      • 876
      True and that may be the best way but was wanting to try to start with a measurable gap and not with some too thick if poss.
      79SF
      XJ11
      78E
      • DAVINCI
        • Jan 2011
        • 1048
        I suppose your way would work IF the cam journal is the same baseline as the base of the cam lobe, not sure if it is. I know it's not on automobile cams.
          I would agree with davinci. There really isn't a reliable way to do it without shims.
          • mack
            • 2411
            • Ontario, Canada
            Seems to me
            that both my motors had more 270's than anything else. I'd get four of those and check the clearance off those for both intact & Exhaust.
            mack
            79 XS 1100 SF Special
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            https://youtu.be/wB5Jfbp6SUc
            https://youtu.be/RaI3WYHSuWA
            Frankford, Ont, Canada
            613-398-6186
