How tight should one tighten the nuts on the top of the triple tree?
How tight?
How tight?
Theodore RooseveltTags: None -
On the tripple tree, the upper fork clamp bolts are 14.5 ft-lb. Lowers are 12.5 for standard, 14.5 for specials. Page 207 in the service manual.John (XSive_Speed)
'80 XS1100G Standard
- 4 - 1 exhaust (probably Mac)
- UNI air filter -
I am talking the nuts that hold the stem in the steering neck.Nathan
Theodore RooseveltComment
Assume you mean the pre-load on the tappered rollers Nate?81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
yes. The nuts that hold the shaft with the bearings on it in.Nathan
Nate, the FSM gives a torque of 7.2 to 8.7 ft-lbs, but then goes on to say to 'adjust it if there's any binding or looseness'. A bit weasely...
I use the 'fallaway' method. To do this, get the front wheel off the ground, remove the handlebars (this is to remove any influence from the cables), then center the wheel pointing straight ahead. Gently push on the front of the wheel (either way) until it 'falls away' to full lock. If the preload is right, you should be able to push the wheel between .5" and 1" before this happens. Less, not enough preload; more, too much. You want to see the same both ways. This has always worked very well for me.
One other thing; Scott reported that after setting preload, when torquing the stem nut this increased preload, so you may have to take a few shots at this to get it right...Fast, Cheap, Reliable... Pick any two
Well then I guess at this point it doesnt matter cause I dont have the whole front end together. But now I know! Thanks Steve!Nathan
