The calipers are really simple, just a chamber with two holes, one for the in from the MC and the other for the bleeder. The only other thing is where the square o-ring goes which needs to be cleaned of any dirt and corrosion. Other than that, they are dead simple. The master cylinder is a little more complex with the spooge hole, but even it is pretty simple compared to a carb.
Dirty Brake Line
Nope, the single-piston calipers on these bikes are pretty basic. You've seen all there is to see.
When you get the master cylinders, it's a different story. Both have several small holes that have to be clear to function right, and these can be a PITA to clean. On these, any 'gunk' left in the system can be a real problem; that's why it's so important to get the system clean....Fast, Cheap, Reliable... Pick any two
Here's the master cylinder problem explained...http://www.xs11.com/forum/showthread.php?t=14
Note that he's doing this without disassembling the cylinder. The only problem with this is you don't know what's inside the bore. If you have any crud in there, this will quickly clog again, so it's best to just bite the bullet and fully disassemble and clean them. Then you know it's good, and won't have to worry about jammed brakes...Fast, Cheap, Reliable... Pick any two
Ok. So I am almost done cleaning the pistons, then afterwards I will clean the hoses and master cylinders.
Is there a way to test the brakes before I jump on the bike and take off? Obviously, I can engange the break and push the bike and see if it moves, but that really wont tell me if its going to work at 60 mph on the highway.
Adam
as long as u have a fairly solid lever,
thats a good start, then ride it slowly
to check that the brakes are working,
did u put new pads in?
if so the'lly need to be bedded in,
also if uve cleaned the m/c u'll want to bleed it,
i do this on the bench stuck in a vice,
before attaching it to the handle bars.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
If you have a firm lever/pedal after you reassemble and bleed the brakes and you don't have greasy/oily pads you should be fine.Fast, Cheap, Reliable... Pick any two
