Hello all,
I finally got my bike running after it has been sitting for who knows how long.
I am afraid the clutch is not working properly and I have some questions.
With the bike turned off, I can static shift through all of the gears. However, if I put it into any gear and pull in the clutch I cannot get the bike tire to spin freely. I can sit on the bike in 1st gear with the clutch pulled entirely in and with all my might I can not push the bike forward.
Where should I begin looking? I was thinking that the clutch adjustment screw has to be adjusted.
I know the screw is under the cover on the right hand side. I do not remember the exact procedure. I know I first loosen the locking nut then do I turn the adjusting screw in or out all of the way? Do I back it in our out a quarter of a turn?
Thanks,
Adam
Thanks,
Adam
However, once it's in gear, it should STAY in gear until you shift again. If it tries to jump out of gear, you'll need to look into the "2nd gear fix", which can technically be attributed to ANY gear. The major symptom is generally described as a "machine gun" sound when you try to shift.
