Hey everyone. I'm having problems with rear turn signals on my 1980 11g. L/side works as should, but when I turn on the R signal, the four ways turn on steady? I figure since the left side works properly and both signals are fed by one set of main wires, it has to be the wires going to that side or maybe the socket,etc.(The socket seems to be very corroded.) I 've been reading prior posts and I'm not sure if rear signals should running and signal lights or single filament turn signals only? Please, if anyone knows I would very much appreciate any help. Thanks, Dave
are my signal lights factory?
Stick should be singal filament 1156 bulbs. Lot of people do change them to running/turn signals but then the lenses MUST be red.
You must have some wires crossed that should not be if they are acting like that. If they are as dirty as you make them sound I would start with cleaning everything and see what comes up on that process first.Nathan
Theodore Roosevelt -
A poor ground on one or more lights will cause that.... check/clean the grounds.Fast, Cheap, Reliable... Pick any two
1980 xs1100gComment
It grounds through the socket, on the socket there will be a small ground strap that goes on a screw that holds the socket in place, that grounds the socket to the signal stem. That then grounds to the fender/frame/triple tree depending on your setup.Nathan
Theodore RooseveltComment
the left side that works has a nice clean shiny silver socket. theStick should be singal filament 1156 bulbs. Lot of people do change them to running/turn signals but then the lenses MUST be red.
R side that doesn't work is pretty corroded.1980 xs1100gComment
The front signals ground through the bracket/lower tree. The rears should have a ground wire that goes under the stem nut, then goes and plugs into a ground wire in the harness. The fronts aren't usually a problem, it's nearly always the rears...Fast, Cheap, Reliable... Pick any two
thanks for the info. much appreciated. just trying to learn as much about bike as possible. i don't see any sense ridin' one unless you know at least enough to help if ya get stranded. not to mention trying to have dealership chase wiring probs at $60 per hour!1980 xs1100gComment
not to mention trying to have dealership chase wiring probs at $60 per hour![/QUOTE]
I wish the yamaha dealer here charges $110 per hour!!!
'79 XS11SFComment
On top of that, I want to know enough to get UNstranded, not stranded.
