Well guys here it is. I just got running well enough to take her around the yard and start tuning it. As I pulled up and parked it I noticed a couple drip spots and it appeared to come from the oil overflow tube. So I changed the oil and busted it off. After running about fifteen seconds it started pouring oil everywhere! What the he'll over?
why is my oil overflowing?
It's really a crankcase vent not a oil overflow . How much oil did you put in . That usually happens when there is too much oil in the crankcase.BDF Special
Dyno tuned to 98 hp at the rear wheel. -
Ummm...you either have a major hick up in the giddy up or just me confused.
First, the drain plug for the middle drive is under the bike behind the tranny pan, almost to the swing arm. If you pulled that and nothing came out, you REALLY want to pull the fill plug and check the fluid level in there. If it is dry, and you ride it, it will lock up, and that will = NO FUN AT ALL!! Most likely going down hard!
Secondly, put the bike on the center stand or have someone hold it close to level and look at the oil level int he sight glass on the lower back of the clutch cover, by the right hand foot peg. Should be between the two lines.
There is a smaller vent line off the middle drive as well as the crankcase breather line in the same vicinity. If the middle drive is over filled, it will also dump gear oil out its vent.Life is what happens while your planning everything else!
78 XS750Comment
hi trash,
can u take a pic of that small hole,
there is a small looking hole on the middle drive
thats been there from the manufacturers so it might not
be a problem, there have been previous posts about it
but couldnt find anything when i searched, fill the mid drive to the correct level and see if it does actually leak to be sure.
the mid drive oil is normal 80/90 gear oil, the amount is 300cc/10 us ounce,
if u dont have a manual,check out member catonicbugs signature, u can download one from there.
also be sure to drain the xsive engine oil.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
-H. FordComment
And the oil drain plug is at the front of the oil pan just behind and to the right of the oil filter cup if you're looking at it from the front of the bike. It's I think IIRC a 19mm head on it, I think the same size as the middle drive drain plug (and the FD drain plug as well) although I could be misremembering. I'm pretty sure about the oil drain plug, but it's been a while since I've done a middle or final drive (it's just about due, probably do it this weekend while I'm doing my other mechanical stuff on the car (ok, electrical actually).
I know that even if you overfill the middle drive, at worst it seems it just pukes the oil out the overflow tube and all over the back tire. The FD if over full will seep out the fill plug and get things all nice and greasy so they attract dirt and make it look really well used.I don't wash most of the bike too often, but I spray purple power on the shaft housing, engine and FD every couple of months and rinse it off after about 15 minutes. Keeps the grime from building up too much. Much easier to keep up with it if your FD isn't puking oil all over the side of the rear tire through the seal.
PS, I picked up the "real deal" dipstick from my Yamastealer for less than $10 last summer. Makes a nice addition to the pile of tools I keep in my right side saddlebag that I use primarily as a toolkit.Cy
Looks like you're right pete. I used my comealong to pick my assend up and it was a bolt holeAfter I get some gear oil in the morning I get to go for my first ride! I had to stop to go check out another bike. Traded and old nonrunning four wheeler for a water cooled maxim. Don't know what it is, but its got to be worth it. I really appreciate the support guys. Any of y'all take a road trip to south georgia the beer is on me!
nothing like a happy ending hey. :-)
glad it was nothing to drastic.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
