Hi,
On my new 79 special, the starter worked fine last fall. Now I tried to start it, on three attempts within five minutes of each other the starter would turn over the engine, but the starter sounded like it would disconnect and spin freely when the engine did not start. After charging the battery, the starter an hour later, just spins and doesnt connect to the engine to roll it over.
I did some searching, and came to the conclusion that the starter clutch is prolly not connecting, and this may be due to having summer weight oil in the engine. Is this starter likely at all to work if I just put lighter oil in the engine? I do have a kickstarter for it, and will try that, but I know I would rather have a working electric starter.
In addition to the above mentioned standard kick starter for the 11, I have an xs 750 engine with its kick starter. I believe the seven fifty is about a 77 maybe. Is this folding kick starter likely to work on the eleven from 79? The eleven doesnt presently have side covers so the info from search with its warning about hitting the side cover isnt valid at least for now.
Please tell me , what is the likely outcome here. HELP
