Carb air screw
  • James England
    • 3039
    • North of England
    Carb air screw
    Hi Folks. I have the 'old style' carbs on my 1979 bike. ie the original XS1100 carbs before they changed them I've been reading (probably too much) about these carbs from various sources but need to verify some conflicting info.
    What effect does screwing the mixture srew clockwise (ie screwing it 'in') have? Does it richen the mixture by increasing the amount of fuel going through or does it weaken it.
    Just about every carb I've personally known, it richens the mixture when screwed in. Unfortunately, the Haynes manual has nothing about this because we're not supposed to touch them because of emissions (I assume).....
    Yes, that is true. The screw controls the flow of air being mixed with the fuel. Opening (unscrewing) the screw will add more air, leaning the mixture, while closing (screwing in) will reduce air flow, richening the mixture.
    • SFerinTEXAS
      • Jun 2006
      • 877
      Sorry Cat, not so. The idle mixture passage is a fuel passage. Screwing in the screw shuts down that fuel supply.Backing it out increases it . Once backed out so far any additional backing out is irrelevant Fully open is fully open.
      79SF
      XJ11
      78E
      • SFerinTEXAS
        • Jun 2006
        • 877
        To explain further. This passage gets its fuel from the pilot jet circuit. Because it is in front of the butterfly, at closed throttle it feels the vac of the intake much more than the 3 pilot orifices so the effect of the screw interfering with the fuel is greatly magnified thus the effects on idle mixture at closed throttle. When the butterfly's open it becomes just another pilot jet supply port. All the fuel in this passage is mixed with air from the pilot air jet
        79SF
        XJ11
        78E
        • TADracer
          • 1417
          • Kenner, Louisiana USA
          And to add to that....
          Once your idle mixture screw is so far out it has no effect, if you are still to lean then it is time to go up one step on the pilot jet.
          Mike Giroir
          79 XS-1100 Special
          • mack
            • 2411
            • Ontario, Canada
            Pilot
            Wouldn't you change the C clip setting first?
            mack
            79 XS 1100 SF Special
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            https://youtu.be/wB5Jfbp6SUc
            https://youtu.be/RaI3WYHSuWA
            Frankford, Ont, Canada
            613-398-6186
            • cywelchjr
              XS-XJ Super Guru(Deceased)
              • 4450
              • Sacramento, CA
              No, the c-clip has no affect at idle, it kicks in during the transition from idle to mains.
              • mack
                • 2411
                • Ontario, Canada
                regret
                Ya , as soon as I clicked send I realized my mistake. That happens at 2500 rpm?
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                  Isn't it somewhere around 4ish turns out where you need to change pilots?
                    2500-3500 ish
                      When to change jets all depends, I know some folks who have run with their mix screws 5 turns out. Some like it under 4 or even 3.
                      I would agree that if your already 5 turns out and see no improvement or very little, then I would no doubt about it jump the jets up.
                        Oops... Thanks for the correction...
                        • lee_dutcher
                          • Apr 2009
                          • 822
                          • mason city iowa
                          sorry for the hijack... but what if the needle is screwed in to far and the needle tip is jammed inside
                          1980 gs1000g "stock"
                          • lee_dutcher
                            • Apr 2009
                            • 822
                            • mason city iowa
                            lol....................
                            • cywelchjr
                              • 4450
                              • Sacramento, CA
                              Actually it's not really RPM based, but rather airflow based, which while having some relation to RPM, is really more the throttle setting, as if you open the throttles all the way, the slides move up sooner. It's actually IIRC about 1/3 that the mains really start to kick in, and by about 2/3's or so your mostly on the mains. This is at least as I understand how CV carbs work.
