GSXR Carbs fixed my problem! (long)
  • stevec5000
    • Oct 2002
    • 131
    • Mesa, AZ
    My stock Mikuni carbs have always been a problem, one has a crack and leaks fuel and the needle valve seat O-rings leak every year and have to be replaced. Besides performance has always been poor. When the needle valves themselves began to leak and I replaced them the fuel wouldn't flow into the carbs fast enough to keep the engine running at speed and it would run out of fuel on the freeway. I thought about getting replacements but realized that any I found would also be as old as mine and still pieces of crap even if they were in good shape. Yamaha seems to put the cheapest carbs they can find anywhere in their bikes, like Hitachi's on some models, yuck! The carb companies make better ones like RS flat slides but the cost is too high, at $250 each.
    After a lot of searching I settled on Suzuki GSXR 1100 stock carbs which have flat slides but are also CV type. They are 36mm but still 40mm on the outside and will fit the XS1100 rubber boots. The only major problem is the spacing between the center two carbs is a bit wider and had to be reduced to fit the Yamaha. I got a set on ebay for $70 that looked perfect and were just like new. I had to cut a piece out of the middle of the bars that hold the carbs together with a bandsaw and moved them together so the butterfly shafts just touched and cut the bar that operates the chokes and overlap the end to secure them with a screw. The carbs are designed for dual push-pull throttle cables but the single pull cable will work with an extension. They are also made to use a cable operated choke. I tried a push-pull choke for a car but it was hard to pull and wouldn't stay out. I decided on the speed shift lever from an 18 speed bike and that works great. It mounts on the bars, is easy to work and stays in any position. They can be found at swap meets or bike shops if there isn't an old bike laying in the back yard. Get the kind with a plain lever with no click stops or racheting mechanism and get the cable to go with it. You will also need a 6mm cable stop to clamp on the end of the cable that goes into the carb. I found a 1/4" stop at Auto Zone and turned it down to 6mm in a lathe. The stock airbox has to go unless you can find a way to get the rubber boots to fit the bigger 60mm inlets on the new carbs. I already had pod filters but they won't fit so I cut out the opening with an X-acto knife to use them for now. K&N makes a set of dual filters that are oval and have two openings so each one fits on two carbs but they are expensive. It was a bit tricky to get the carbs on at first, I had to loosen the screws in the two outer mounting boots so they could swing out a bit and sprayed the spigots with WD-40 to get them to go in easier, then tightened up the bolts after I got the carbs in. The GSXR 1100 has #122.5 mainjets and #30 pilot jets so the jetting was just about perfect. All I've done so far was change the pilot jets to #35 to make starting easier and stop some of the popping when cold. The old XS carbs had #45 pilot jets but they don't need to be that large. I left the needle clip in the 2nd position form the top. The mixture looks good and will pass emissions with no problem. I think just about any 36mm GSXR 1100 or Bandit 1200 carbs will work as long as they are from an oil cooled model. The ones from a GSXR750 or 600 sport bike won't work because they are downdraft. Also the Bandit has #102 main jets so they may need to be changed. There are no fuel leaks now, the bike runs much smoother and the accelleration is a lot better, especially during roll on from 40-80 or while passing. Now it feels like and 1100 again, not a 750 in a 600 lb. chassis. There is currently a set of GSXR 1100 carbs on ebay for $99.00, not bad for new carbs. The only problem I haven't completely solved yet is adjusting the idle mixture screws which are on the bottom of the carbs at the front. I can't get to the middle two carbs to adjust the screws unless I remove the whole rack but 2 to 2 1/2 turns out seems to be about right. I'm going to take pictures of the installation and put up on a website
    when I take the whole assembly off again for some more work.
    72 TS185
    77 XS750
    78 SR500
    80 XS850
    80 XS1100 Midnight Special
    81 Seca XJ750RH
  • Shuriken
    • 1093
    • Southwest USA
    This is quality material. Please send pics as soon as you can. I wonder what they cost new. Do they have diaphragm assemblies inside as well?
    What's the E-Bay item number?
    Ben
    Formerly:
    1982 XS650
    1980 XS1100g
    1979 XS1100sf
    1978 XS1100e donor
    • stevec5000
      • Oct 2002
      • 131
      • Mesa, AZ
      The Item number is 2434801019. Just search for "GSXR carbs". I would hate to think what they cost new but flat slide carbs are usually over $800 on ebay. Someone else is selling 2 sets of carbs on ebay, Item number 2434883193. I think any set from a '90's 1100 or 1200 will work.
      Yes, they have diaphram assemblies. The diaphrams are made of quality rubber and in good shape since they are so new. The tops are plastic and held on by just 2 screws so they are easy to get off with the carbs on the bike. If the top is removed be be careful not to lose the small O-ring. The flat slides are plastic and very light so you get very fast throttle response. I've found that is is possible to jerk open the throttle so fast it almost kills the engine or make it ping. I'm considering plugging one of the two holes in the slide to try and slow it down a bit.
      Also, make sure the mechanical and vacuum advance is working or the engine will have a problem running rough just off idle from about 1500 to 2000 RPMs. It took me quite a while to find that. When installing the vacuum hose connect it to the port on one of the carbs instead of the intake manifold, the vacuum is smoother there.
      72 TS185
      77 XS750
      78 SR500
      80 XS850
      81 Seca XJ750RH
      • Racer X
        • Jun 2003
        • 42
        • Vancouver, Wa.
        You know, somewhere, someone has one of these bikes with a Holley four-barrel mounted to it...............
        '80 XS 1100SG
        • stevec5000
          • Oct 2002
          • 131
          • Mesa, AZ
          I was thinking of using a couple of Weber side draft carbs, I have some already jetted for that size engine. Only reason I didn't was because I would have to build a manifold from scratch.
          72 TS185
          77 XS750
          78 SR500
          80 XS850
          81 Seca XJ750RH
          • ratbyk
            • 994
            • Sooke BC
            Fitting Carbs
            Steve, I think that you will really be challenged for space to fit 2 DCOE 40 OR 45's in the room available behind an XS11'S engine.
            Ken/Sooke
            78E Ratbyk
            82 FT500 "lilRat"
            • Bill
              • 368
              • Fairfield, Calif
              Re: GSXR Carbs fixed my problem! (long)
              Great original work, Steve! It's a landmark piece that opens up an entire new source for maintaining and possibly improving the XS11.
              A lot of bikes came with the push-pull throttle and show up on eBay from time to time. Looking through the Dennis Kirk catalog, it looks like they were most prevalent on '70s and '80s Hondas and Kawasakis. I don't know if the knobs on the end are the same. Aftermarket push-pull throttles are also available.
              They're also available new from online bike catalogs such as Alfred E. Bike and Bike Nashbar
              The Katanas also shared these carbs with the GSX-Rs. Some late model 600/750 may be downdraft, but most of the air/oil cooled Suzukis had side drafts. I'm using a set of GSX-R 750 carbs on my GSX-R1100.
              Ain't that a pain!? I tried making a really short screwdriver to adjust them, but it's easier to just pull them out... especially with individual filters.
              Outstanding! Looking forward to seeing your pix and further documentation.
              XSively,
              Bill K.
              1985 Yamaha XJ700 Maxim
              1986 Yamaha FZX700 Fazer
              • stevec5000
                • Oct 2002
                • 131
                • Mesa, AZ
                UPdate: I recently got another set of Suzuki carbs for a 1990 GSXR750. These are 34mm and look just like the 36mm version for the GSXR1100 that I used on the XS1100. They are almost the same size as the XS carbs and look like they will fit without any modifications but I haven't tried them yet. The spigots are slightly smaller in diameter because the walls are thinner but will probably fit ok. They also use only one throttle cable and the intakes are the same size as the XS making them easier to adapt.
                Best of all they were only $30.00 on ebay!
                72 TS185
                77 XS750
                78 SR500
                80 XS850
                81 Seca XJ750RH
                  Hey Steve,
                  I've been conversing with WiredGeorge, the guy who posted about the carb repair/rebuild business he runs out of Texas near San Antonio. He's been doing this for over 15yrs, mostly KZ's and Suzuki's, but is going to be branching out to XS/XJ11's and his prices are a fair bit better than Rob Reil's!!!!
                  He told me that the spacing for many of the KZ's, and GSXR's is about 77mm-93mm-77mm, both the 750 and 1100. I just measured mine, and it's about 78mm-84mm-78mm which shows the narrower spacing inbetweent the #2 and #3 carbs!
                  So, just wanted to touch base and find out if those 750 carbs were just as wide in the middle as the 1100's?!
                  • Bill
                    • 368
                    • Fairfield, Calif
                    TC -
                    As far as I know, all the air/oil cooled GSX-R carbs are spaced the same... 750, or 1100. Here's a link to a spacing chart at Carb Parts Warehouse:
                    Mikuni Tuning Specifications
                    XSively,
                    Bill K.
                    • chevy45412001
                      • Mar 2003
                      • 1412
                      • Jacksonville Florida
                      fj1200
                      Not a different carb but bigger (36mm-38mm) is the fj1200 yammy carbs. they also use the two cable set up but pretty straight forward bolt on to the xs-xj. But this looks just like our carbs with the same parts inside. Just a thought
                      1982 XJ 1100
                      • Bill
                        • 368
                        • Fairfield, Calif
                        FJ carbs
                        A good substitute if you can find them. Plug & Play. I don't know if they fit the stock air box boots.
                        GSX-R carbs (Air/oil-cooled engines, 1985-1992)
                        Plentiful, but they're narrower front to back (approx. 93 mm vs 113 mm). Individual filters are necessary, unless someone wanted to build an extension/adapter to reach the air box.
                        Regarding spacing
                        In his original message, Steve5000 wrote,
                        XSively,
                        Bill K.
                        • stevec5000
                          • Oct 2002
                          • 131
                          • Mesa, AZ
                          The 1990 GSXR750 carbs didn't work out. Even thought they fit on the manifolds ok all the jets were too small, even the air jets and I think the needle jets too. I tried increasing the jet sizes but never could get it to run properly so I went back to the Katana 1100 carbs. The jets are much closer to the required size. There is a problem with spacing between 2 & 3 however. I had to cut the horizontal bars holding them and remove about an inch of material to get the two carbs as close as possible.
                          There is still a bit of mismatch concerning spacing but they can be forced into the rubber manifolds. However the strain tended to pull the #2 & 3 carbs out of alignment which caused the throttle cable to stick and I couldn't get to the idle mixture screws. I solved that by making some extension tubes out of steel pipe that fit into the rubber manifolds then mounted rubber carb adapters for an XS850 onto the pipes to hold the Suzuki carbs.
                          The extended length allows the ends to be pulled apart a little more so the carbs fit without any strain and spaced them out far enough from the engine so I can reach the idle mixture screws.
                          72 TS185
                          77 XS750
                          78 SR500
                          80 XS850
                          81 Seca XJ750RH
                          • Geezer
                            • May 2003
                            • 2985
                            • Willamina, Oregon 97229
                            I have a set of KZ1000 carbs that I plan to adapt for use on one of my XS11s. I've never liked CV carbs and I can't wait to replace them.
                            Geezer
                            • pgg
                              • Jul 2003
                              • 394
                              A true flatslide or smoothbore 34mm carb would be equal to a whopping 38 - 40 mm CV carb in flow rates. An XS11 with 34mm CV's would only need a 30mm flatslide carb at the most. I've run bikes (not an XS11 though) on smoothbores and, being honest, they were always a pain in the a**! They're not 'flexible' - more like on/off switches. The stock carbs on my XS11 have always performed brilliantly. Geez, those kwaka carbs would be different again, but give me CV carbs anyday.
