This is something that I have not run accross before....Gas was running out of #4 carb...I tapped on the float chamber but it kept running out. So I removed the bowl, trimmed the gasket (just in case), removed the float assy.. With the needle out, I held my finger over the needle valve fitting and turned on the gas to check for any other leaks and to my suprise, gas came out in about every place that it could under the carb
......I thought that the gas had to go thru the needle valve into the bowl before it went anywhere else....Mikuni carbs.....any thoughts???
