my 80sg has 110 main jets on all the carbs. on the carburetor facts page it seems to show it should have 110 on 1 and 4, and 120 on 2 and 3. What is normal? Im getting ready to add pods and i would like to know what it should have stock. Thanks again for any help guys.
what are the stock main jets for 80sg
Yamaha jetted cyls. 2 and 3 richer to keep them cooler (less cooling fins), but that idea was scrapped. Most run the same size across the board when re-jeting. Just use this chart....
Yamaha put 120's in #2 and #3 carbs so the inside cylinders would run a bit cooler. But 110's or all the same jet sizes across is normal to see. Some people find they don't need to rejet with pods and some do, all depends on where you are (sea level) and what your set up is. Stock exhaust etc.BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
