I just read thru wingnuts's thread on the steering damper, and it's got me thinking about my own steering issue. It's been going on so long that I have gotten used to it, but maybe someone has a fix.
History: Bought this still- nameless 80g w/ Vetter fairing & hardbags in '06. Found that the bike's steering would seriously wobble starting at 90mph, my impression was such that I expected it would increase into a tank slapper. Having gone thru that scenario 20 yrs earlier, I know how that ends up.
So I slow down, cars routinely pass me, I buy and install a TKAT brace. Better. Can get to 105mph (hypothetical)
before it hints of a wobble. Pretty tolerable, I judged it "problem solved".
Then I shelved the Vetter fairing and it's bracket. Replaced it with one of those clear Lexan fairings that mount to the handlebars. It extends to below the turn signals and also blocks the handgrips. The wobble shows up at the same 105, but seems more pronounced. I installed new tires. New steering head bearings. New Progressive heavy duty fork springs. No air in forks. Stock rear shocks. About 47K miles on the bike.
It feels like what a kite trying to fly with no tail looks like. The original wobble felt like it came from the road up, now my impression is the source is this lighter fairing.
I was thinking to add a steering damper, but that's a bit off track without first experimenting. Remove the fairing and make a run. Maybe reinstall the vetter?
My objective is to be stable enough to feel like the bike is running on rails at 110. Anything faster is just too fast for me anyway
Anything else to try, or measure, or?
before it hints of a wobble. Pretty tolerable, I judged it "problem solved".Then I shelved the Vetter fairing and it's bracket. Replaced it with one of those clear Lexan fairings that mount to the handlebars. It extends to below the turn signals and also blocks the handgrips. The wobble shows up at the same 105, but seems more pronounced. I installed new tires. New steering head bearings. New Progressive heavy duty fork springs. No air in forks. Stock rear shocks. About 47K miles on the bike.
. Anything else to try, or measure, or?
. Interesting that you're looking at the back of the bike. The swing arm bearing is something I never looked at. It's an arm, it swings, it gets grease in the zerk fitting each year. Now I'll need to learn more about that. BTW, I'm lately running 35psi front, 38psi rear. I have seen no obvious frame issues, and the forks are as parallel as I can quantify. Oh, and the rear shocks are set at #4 on the little dials on top, and the stiffest setting on the bottoms.
... I snap a chalk line 20' thru the garage and cover the first 10' w/ clear packing tape. then walk the bike slowly down the chalk line and see where the chalk prints the rear tire (hopefully the center). Clmer's, p.221 explains how to measure the centering of the swing arm in the frame and how to adjust it. I'll do that before the chalk walk.
