Front engine mount bolt dimentions?
  • XSive_speed
    • Nov 2010
    • 45
    • Cedar Rapids, IA
    Hello all,
    Does anybody know the correct size, length and bolt grade for the front engine mount bolt? It looks like mine was "improved" about 2 PO's ago, and its still not right. I would like to but this back in stock condition.
    Thanks,
    John (XSive_Speed)
    '80 XS1100G Standard
    - 4 - 1 exhaust (probably Mac)
    - UNI air filter
    • 8861
    It's 8MM X 1.25 pitch, 295MM long. The threads are cut 22MM down the bolt from the end, head size is 14MM and has "8" stamped on it, possibly the grade. Note: if you are using 3 point crash bars, you'll need one a bit longer. HTH
    • SFerinTEXAS
      • Jun 2006
      • 877
      Suggest you contact andreashweiss on this site. He surely has a boatload of those.
      79SF
      XJ11
      78E
      • XSive_speed
        • Nov 2010
        • 45
        • Cedar Rapids, IA
        Thanks all - thats exactly what I needed to know.
        John (XSive_Speed)
        - UNI air filter
