Hi- new owner of XS1100.
    replied
    Originally posted by SFerinTEXAS
    And if those are factory exhaust the 81 std had the shorter mufflers sorta like the specials. Correct?
    It's not oem exhaust.
    Leave a comment:
  • SFerinTEXAS
    replied
    Leave a comment:
    replied
    ...All the above evidence is pointing to a very nice bike but away from an 81 Venturer...
    After looking at the pic closer, Phil's right; that's not a '81. That's a '80 standard (unless it was serialed as a '81 but was a left-over '80) and the giveaway is the right-side muffler/footpeg mount. The '78-80 standard frames were pretty much all identical, with only the sidecover mounting tabs being the big difference. The '81H frame was a cross between the standard frame and the Special frame, being basically a Special frame with the addition of the U-shaped hinge bracket for the rear fender. The muffler/footpeg brackets won't interchange between the '78-80 standards and specials as the frame mounts aren't in the same places, so with that type bracket it's a pre-81 standard frame.
    Leave a comment:
    replied
    Thanks Nate,
    Both VIn would be the same for a factory bike.
    Apparently there were Specials too in 81. Pehaps it was that Standards came only as Venturer in Canada. Indigo Blue is consistant across US & Canada as the colour.
    Yes both would be the same from the factory but the engine could have been changd in the last 30 years. Steering neck vin is going to tell you what your frame is and be more accurate more so than the engine vin. But look at both and compare!
    Leave a comment:
    replied
    Thanks Nate,
    Leave a comment:
    replied
    Hi Throttle Jockey,
    All the above evidence is pointing to a very nice bike but away from an 81 Venturer. AFAIK In 1981 Yamaha only sold the Venturer model. Can one post the link to Serial Numbers? that will tell for sure.
    If it is a Frankenbike it is certainly well done.
    xs11.com/faqs/153-serial-numbersmodel-designationsfactory-colors.html
    And look at the steering neck vin, not the engine vin.
    Leave a comment:
    replied
    Hi Throttle Jockey,
    Leave a comment:
    replied
    ...From this angle the tank looks like a standard not the extra large....
    Very definitely a standard tank. They're actually easy to tell apart; the standard tank knee indents are rounded at the front, while the Venturer indents are straighter at the front and slanted forward.
    I'm with Phil; if that olive color was a mint green, that would be a very pretty bike. Not that the bike looks bad, but some peoples color choices do make you wonder...
    Leave a comment:
    replied
    Either way, a bunch of money was spent on that bike to make it look like it does. BTW, those muffs are Jardines....no longer available. Hate to see it get whacked up, but to each his own.
    Leave a comment:
    replied
    If that olive green color was a light green (think Bel-Air), that'd be awesome looking. .
    Leave a comment:
  • ThrottleJunky
    replied
    Yeah, all the bags, etc. are Vetter. I found the label on them. What's interesting about it is the "MacTools" logos on the bags (ugly), and the fact that the keys and locks are "MacTools" too. Not sure what that's all about. The guy I bought it from was very proud of the bike, and seemed to kind of lament letting it go. It very well may have an aftermarket exhaust. I think the seat is, too. I think it was taken care of.
    After further review, I don't think it's stock exhaust, either. It flairs out on the end. I think this bike was customized right after the guy bought it, or maybe some MacTools promotional thing from the early 80's. Who knows?
    Leave a comment:
    replied
    HiThrottle Jockey,
    Yeah a picture. My 2cents. Fairing and bags are Vetter.
    From this angle the tank looks like a standard not the extra large. Are the Yamaha logos held on with screws?
    Be careful when assembling the clutch. Check the tech tips for details so you do not break anything.
    Leave a comment:
    replied
    That does not look like stock exhaust.
    Leave a comment:
  • ThrottleJunky
    replied
    PS- Not the prettiest of colors, I know, but consider the era. The bike won't look anything like this when I'm done with it.
    Leave a comment:
  • ThrottleJunky
    replied
    The brake system is done. I need to pick up a clutch pack, or order one online, and get it in next week. Here's a pic of the bike. I am going to sell off the full fairing, windshield, saddle bags, trunk, crash bars front and rear, and seat. I'd like to get as much as I can so I can put that money into a single seat, and some modifications. The clutch housing cover is off because I was checking the adjuster. The bike is actually close to mint. I also have an extra standard tank that I will sell. The only thing I don't have is the reflector on the rear guard. From what I can ascertain, the bike has never been down. The exhaust is pristine with only one tiny dimple on the passenger side. The crash bars have no scrapes.
    Leave a comment:
