Rear air shock oil?
  • thecamelman79
    • Dec 2010
    • 81
    • Havelock, nc
    Rear air shock oil?
    Any body know how much oil needs to be put back in once you've drained them?
    On xj1100 air shocks.
    Thanks
    ~Camel
    • 8894
    Should be near the end of this write-up....
    • Cobia
      • Jul 2007
      • 1587
      • Palm Beach County, Fl
      According to the factory manual, for which I paid way too much for, it says to fill it to the 75mm level (2.95in). It says to use Vernier calipers to measure this. What the base for this measurement is, I don't know.
      1980G Standard, Restored
      Kerker 4 - 1
      850 Rear End Mod
      Automatic CCT
      1980GH Special, Restored
      '82 XJ1100 (Sold)
      • thecamelman79
        • Dec 2010
        • 81
        • Havelock, nc
        Thaks man. I new this thread was here some where. Just couldnt find it.
        • thecamelman79
          • Dec 2010
          • 81
          • Havelock, nc
          Then this is gonna burn your britches
          found it a few minutes ago.
          I personally like to keep the lap top in the garage with me for referance.
          • Poprock
            • Apr 2005
            • 594
            • Oregon Coast
            Take off the air hose. Take off the thing the air hose screws into. Measure from the flat surface down to the 5w. oil you just put in.
