80 head, 81 head, valve train compatability
  • petejw
    • 2269
    • sydney australia
    hi nate
    i guess anythings possible if u have the money
    to spare,
    the milling of the caps and head wouldnt be to much of a
    problem for a machine shop,
    finding bearings to suit might be another problem,
    also ud have to notch the head to stop the bearing from
    spinning. hopefully parts will be a plenty for some time
    not to have to worry bout it.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • Ken Talbot
      • 4251
      • Revelstoke, BC
      You could probably install the caps and have the heads line bored to a larger diameter so you could insert bearing shells. $$$ Then the only trick would be finding bearing shells that would fit.
      Ken Talbot
        I don't plan to or want to do it, I was just thinking out loud.
