The oil galley plug at the bottom of the alternator is usually held in by the alternator cover. I know I have heard of at leas one other member removing that plug and threading the hole, replacing it with a threaded plug. Anyone done this, and can tell me what size tap/plug I should use? The o-ring has failed on mine again, and I'm tired of messing with it.
I read trbig's description of how he did it, but he just used 2 threaded plugs, and used the first one to tap the hole. I'd rather not go that route if I don't have to. He also didn't state what size plug he used.
