Fun with valve shims
    The ticking noise you are experiencing could be from a loose exhaust flange and/or bad exhaust gasket. Soak the stud with PB Blaster before trying to tighten or remove the nut to avoid snapping it.
    • cowboybob998
      • Mar 2009
      • 371
      • KC MO
      I tought that allso, was hopeing any way, but i have had 3 diferent headers on it, that is realy what it sounds like, i have this thing setting out side now with a cover over it, think i will just roll it in the house and work on it here so i can get more done on it or i aint never gona get it done, spring is right around the corner, lol
      1979 xs1100 f
      142 main, 45 pilot, Jardeen crosover 4/2, no air box
      floats @ 25.7
      1979 xs1100 F
      1978 gl 1000 goldwing
      1981 gl 1100 goldwing
      !986 venture royale 1300
      Just an ol long haired country boy, come to town to spend some egg money
      when ya get bucked off, get back on
      • petejw
        • 2269
        • sydney australia
        hi cowboybob998,
        did u replace the exhaust gaskets,
        when u tried changing the headers?
        "As it slaps against the engine, the valve and the aluminum engine case slowly wear"
        hi bug,
        thats not correct, the head has a 'seat' pressed into it made
        of hardened steel, theres no contact between the valve and
        any aluminium.
        the valve and seat do wear out over time and closes the gap between
        the valves and cam,
        in the olden days when engines had lifters, pushrods, rockers
        and the wear from camshafts resulted in the gap becoming larger.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
