Accel coil mounting revisited
  • bg241ihc
    • 58
    I just came by a pair of new Accel coils and have started installing them.
    I searched though the posts regarding this project and could not find anything to confirm my mounting position.
    I have used the original holes in the coils core to attach them directly to the original mounts in the frame. This puts the leads coming off pointing horizontally out to each side. I found that after cutting off the top of the round fuel tank mounts for the rubber bumpers (but not the bumpers) there is a good half inch minimum air space from any grounded metal objects and the outside of the coil lead boots. Is this enough?
    This results in a super clean installation with no extra brackets or fixtures.
    Also are there any other things to keep in mind with the coil upgrade? I did not get any instructions with them. I read somewhere that larger jetting may be required. Also some of the posts mentioned the ballast resistor. What's up with that?
    Thanks
    Kawasaki 74 XL400S, 83 550 GPz
    Honda 86 GL1200, 80 XL500S, 82 750 Nighthawk
    Yamaha 78 XS1100E, 80 XS1100G, 92 YZ80
    Suzuki 82 GS650L
    The ballast resistor (if you have one) is mounted to the underside of the top frame rail, just under the left side of the tank.
    I'm sure 1/2" of space is plenty. Did you take some pictures of your mounting method? Please show us how you did it!
      Your Accel coils should be 3 ohm, so if your bike is an 80 or earlier, unplug the ballast and plug the two main harness ends together bypassing it.
        Originally posted by bg241ihc
        ...I found that after cutting off the top of the round fuel tank mounts for the rubber bumpers (but not the bumpers) there is a good half inch minimum air space from any grounded metal objects and the outside of the coil lead boots. Is this enough?
        Should be enough room, but if you have any trouble with misfire, that's the first place I'd look. As far as jetting, you could possibly go up a jet size, but don't need to.
        Ballast resistor? What year is your bike? (This is why it's handy to have that in your sig or mentioned). If you have a '78 or '79, you should have a 1.5 ohm ballast resistor and 1.5 ohm coils if everything is stock. The '80-82 bikes have 3 ohm coils and no resistor. The early bikes bypass the resistor for starting, then switch back though it showing the ignition box a 3 ohm load. As far as I know, all the aftermarket coils are 3 ohm (but do check; running too-low ohm coils without the resistor will smoke the TCI box) so you need to take the ballast resistor out of the circuit.
        • bg241ihc
          • 58
          Thanks for the tips.
          I will post some pictures tomorrow. The bike I have is a 1980. I did locate the resistor and will check it to be sure.
          Suzuki 82 GS650L
          • bg241ihc
            • 58
            Sorry for the lack of etiquette on the signature. I thought I had fixed that. Lets see if this works.
            Suzuki 82 GS650L
              ... The bike I have is a 1980. I did locate the resistor and will check it to be sure.
              If it's a '80, it shouldn't have the resistor (although Yamaha has been known to blur model-year changes, with things appearing after they were supposedly gone). Here's a link to a pic of it....
              Or a PO may have swapped some parts around; that's common enough...
                My bad.... the Clymer wiring diagrams show all of the XS models have the resistor, not just the '78-79. That can't be right, is it???
                • cywelchjr
                  XS-XJ Super Guru(Deceased)
                  • 4450
                  • Sacramento, CA
                  All but the 81's have the resistor. 81 was the first year to get rid of it stock and also removed the centrifugal advance and moved that to th TCI (interesting that the 80 XS400 had the timing curve it the TCI beating the 1100 by a year)/
                  • bg241ihc
                    • 58
                    Here are the pix of my coil installation. After reviewing my "Good half inch" I decided it was more like a good quarter inch, so instead of using the rear mounting hole I rested the core on top of the rear bolt with a small spacer on each side to give added support and snugged up the front mounting bolt which should hold it in place as good as necessary.
                    Suzuki 82 GS650L
                      Can't use Facebook to post pics. Gotta use a site like Photobucket.
                      • bg241ihc
                        • 58
                        I see that it did not work, My image URL is
                        Suzuki 82 GS650L
                          • 3193
                          Once you put the boots and wires on the coils are you going to clear the actual tank by very much? It is hard to tell from the angle of the pic.
                          • bg241ihc
                            • 58
                            It will be inside the metal tank mount shown by the 1/2 inch I mentioned so with the rubber bumper in place there will be plenty of clearance and insulation around the boot for the plug wire. I will try to add some shots that more clearly show the detail with the bumper in place which should indicate the clearance to the inside of the gas tank itself.
                            BTW, Changed the image to photo bucket and it now displays fine. If someone can delete the 2 posts regarding the problem, feel free.
                            Suzuki 82 GS650L
                            • lakecountrydave
                              • Aug 2007
                              • 384
                              • Phoenix, AZ
                              You will need to increase the gap on your spark plugs.
                              Dave
                              1979 XS1100SF Special
