No sparks = no go
    replied
    Sorry for the frustration there Larry. Least having a known good battery eliminates that as being the issue. Sounds like you have a project 1100, so swap out the starter as that is easy enough to do and see what happens. These issues make it difficult to sort out not being there. Persistance WILL overcome these scoots and there needyness. I presume it's the same scoot you had at the rally two summers ago?
    Leave a comment:
    replied
    Are you sure about this? Doesn't an electrical device pull only the amount of current it needs? I just started up a project bike by using thick jump leads off my car battery with no damage to anything at all. It started the engine, I then disconnected the jump leads and that was that.....
    I had to read it 3 times and I think what he was saying is that if something is wrong enough with the starter to pull a car battery down under 10v while cranking it would be pulling enough juice to melt the starter down.
    Leave a comment:
    replied
    Yes, James, I'm sure. Loho has connected a car/truck battery to his bike several times and has not mentioned any pyrotechnics so a shorted starter motor is possible but unlikely.
    If there is no problem then the XS11 starter motor will work with any 12V battery that can meet or exceed the rated amperage for the motor but there seems to be a problem with the starter motor on Loho's bike.
    When the starter motor is shorted then the amount of smoke and light in the show will be roughly proportional to the type of short and the size of the battery used to produce it. A motorcycle battery may not supply enough current for a proper show but a larger battery will do just fine. It is a little harsh to attempt to locate shorts by pouring great gobs of amperage into them until they fail but it does work.
    Always wear safety glasses and have a good fire extinguisher in the work area.
    Leave a comment:
  • DAVINCI
    replied
    James England: Correct, a device will only pull the amperage it needs.
    Rasputin: You got that backwards, the ballast is bypassed during cranking.
    3phase has good advice:
    Check for:
    Bad pickup coil connection at the TCI - Don't forget the harness connector behind the fuse panel.
    Bad or broken pickup coils/wires
    Bad or mis-installed tipover switch
    Bad TCI.
    Leave a comment:
    replied
    Also while checking the starting system, have you checked for any voltage drop from the battery to the starter?
    Is there anyone near you that could give you some hands on help?
    Leave a comment:
  • Rasputin
    replied
    Have you tried removing the ballast resistor and connecting the two leads together to see if you have spark while cranking? A bad ballast resistor can cause the spark when you stop cranking but produce no spark while cranking. Also it does not take a whole lot of starting attempts to run one of these batteries down even if it is new, which will slow the starter down. JAT
    Leave a comment:
  • James England
    replied
    Originally posted by 3Phase
    If you used a car or truck battery (400 to 600 CCA or better?) with regular jumper cables (not speaker wire) there would be a serious smoke leak most likely followed by a shower of melted solder, copper and steel from that poor little motorcycle starter when it drew enough current to pull and hold the voltage below the 10V necessary for the TCI.
    Leave a comment:
    replied
    Originally posted by LoHo
    New battery, same results.
    LoHo, I think you've got an ignition problem and a budding starter motor problem. How much does the voltage drop at the Red/White coil (+) wires when you run the starter motor with the bike's battery? The car/truck battery?
    The '78 to '80 TCI gets full voltage and current from the large Green wire (connects to a Red/Yellow wire that runs up to the TCI) on the starter motor side of the solenoid that bypasses almost the entire electrical supply system along with the ignition ballast resistor.
    While it is possible that the starter motor is burned or shorted internally, check for simple, easily repaired things like bad brushes or a worn/high mica commutator. If the commutator is bad, just get another starter motor unless you know how to re-cut the commutator and grind down the mica insulator strips.
    Even if all of the fuses are missing along with the start button and kill switch circuits, jumping the solenoid from the battery (+) terminal to the starter motor terminal should turn the starter motor and allow the engine to fire up and run until you remove the jumper. The starter motor will continue to run after the engine starts and the ballast resistor is bypassed so don't keep the jumper in place or starter motor will come unglued and, eventually, the TCI will burn up.
    The ignition problem? I don't know, you seem to have checked everything. The single spark when you shut off the ignition shows that the TCI, for whatever reason, is not working and the coils are firing manually when you shut off the ignition switch. That really should not happen.
    Check for:
    Bad TCI.
    Leave a comment:
  • LoHo
    replied
    Leave a comment:
    replied
    LoHo, not sure whether you replaced battery or confirmed it to be good. I'd start with load testing it or taking it to any battery supplier such as Interstate. Most these places have a good carbon-pile machine and load testing charts for specific battery series. That 30sec. test will either show it to be good under specified amp load for a set amount of time in seconds or condem it. Theirs no cost for the test. Putting a meter across battery and showing 12+ volts does NOT necessarily mean a cell or more won't short under load......JAT.
    Leave a comment:
  • LoHo
    replied
    Ken, I've cleaned every connection I can find. I'd love to drag her up the the Great White Nort', eh, but work keeps me local. I took the starter out and hooked it to the battery, and it turned okay, but not as fast as I thought it should. I know...there must be a cruddy wire or juncture somewhere that keeps the voltage down, but I can't find it. I'm thiiiiiis close to parting her out...but then I'd have to join another list and God knows how they'd treat me.
    Leave a comment:
  • Ken Talbot
    replied
    It seems to me that the thing that is causing the starter to slow down could also be affecting your spark. When you say "cleaned connections" I assume you are confiming that you cleaned the battery connections, then I immediately wonder if that means you also cleaned the the various connections on the solenoid, the ground strap connections underneath the engine, the contacts inside the starter switch, and any wiring harness connector plug that might be associated with the starter and the ignition system. I can't help but think there must be some critical point somewhere that is still dirty or just plain loose.
    I don't suppose you would be interested in throwing it on a trailer and bringing it to Revelstoke for a look-see, eh?
    Leave a comment:
  • LoHo
    replied
    Hey guys, would a starter that cranks a little too slowly result in no spark? Or could the voltage drain cause by a weak starter keep it from sparking? Are there adjustments to be made that can improve the starter's performance? New battery, cleaned connections, but still only occasional/rare sparks, besides a single spark that comes as I turn off the key. This is starting to piss me off.
    Leave a comment:
  • SFerinTEXAS
    replied
    What I did do before this .
    Swapped a known good TCI unit
    Unassed the wires in the headlight bucket and jumped past the ignition switch.
    Tested the p/u coils at the TCI , pulled the cover and wiggled my past repairs
    Tested voltage across the unmodified fuse box. Good. Pulled fuses and jumped directly across fuses. Same
    Reassembled and it fired right up.
    Couple days later pulled it out and no go.
    Cleaned the tci plugs and has been fine ever since. Knock on wood. Been at least 10 times it has not reoccurred since. Not certain fixed but has consistently started since
    Leave a comment:
  • SFerinTEXAS
    replied
    recently had a problem on my SF like this. My best guess that I can say fixed it was corroded connections at the TCI plug. Cant say for sure because when you mess with more than one item in a fix its hard to tell what did it. I know when I just unplugged and cleaned and replugged it was fixed. Not the first thing I did but the last. Was there every once in a while, but not up to this point after many runs since.
    Leave a comment:
