Cam chain tenisioner
  • cowboybob998
    • Mar 2009
    • 371
    • KC MO
    Teninsioner off of a 2000 yamaha venture star royal is the same part number as the earlyer venture royals, just bought a set off of ebay for 24.95 + shiping
    I think I will be useing both of them for two xs's i am working on right now, unless some one is in dire need of one.
    Just tought i would let you know that the later model yamaha venture star royals use the same part number, but check for yourself because at some point they may have changed the part as they offten do. these came from pinwall cycles.
    1979 xs1100 f
    142 main, 45 pilot, Jardeen crosover 4/2, no air box
    floats @ 25.7
    1979 xs1100 F
    1978 gl 1000 goldwing
    1981 gl 1100 goldwing
    !986 venture royale 1300
    Just an ol long haired country boy, come to town to spend some egg money
    when ya get bucked off, get back on
  • cowboybob998
    • Mar 2009
    • 371
    • KC MO
    research
    Did some research on bike bandit.com, and all of the cam chain teninsioners from 1983 to 2010 on the venture xvz1300 motor all have the same part number, someone elece may have allready posted this but i did not see it, here it is any ways
    1979 xs1100 f
    floats @ 25.7
    1979 xs1100 F
    • Cobia
      • Jul 2007
      • 1587
      • Palm Beach County, Fl
      Thanks Cowboy,
      I got mine off a 2002 V Max which are the same also. Been running one for 1k miles on my G and put the other one in the J I'm restoring. Don't expect any problems. You do have to use the original bolts because the other ones are too long.
      1980G Standard, Restored
      Kerker 4 - 1
      850 Rear End Mod
      Automatic CCT
      1980GH Special, Restored
      '82 XJ1100 (Sold)
      • cowboybob998
        • Mar 2009
        • 371
        • KC MO
        Originally posted by Cobia
        Thanks Cowboy,
        Thanks on the bolt tip, gona be awhile before i get them, xmas and all, snail mail this time of year, kinda cold to ride but i gess i could just set and lisen to the motor run after i put them on, lol
        1979 xs1100 f
        floats @ 25.7
        1979 xs1100 F
        • ManagerMike
          • Mar 2010
          • 445
          • S.E. Michigan
          Dire need, hmmm, the OE tensioner on my '78 has pulled the helicoil repair threads out of the set screw and I can't seem to find another venture or v-max cct anywhere on fleabay, and spring is just ten weeks away. Is that considered dire need?
          '78 E "Stormbringer"
          • cowboybob998
            • Mar 2009
            • 371
            • KC MO
            83 to 2010
            Do a search as i stated above on 1983 to 2010 xvz 1300 venture motor and there has got to be one out there some where, to late on the extra one i had, allready put it on another motor.
            1979 xs1100 f
            floats @ 25.7
            1979 xs1100 F
            • rover
              • Jan 2004
              • 765
              • central WI (715)
              cam tensioner
              There was a mod using the original adjuster, tapping out the center, and using a 3/8 by 4 inch carriage bolt and lock nuts. I did this before I heard of the self adjusting mod. Must be about three years ago. By carefully feeling the tension, and not getting it too tight, I have checked it several times since, and is holding well. Just have a small seepage around the threads of the carriage bolt. The mod is somewhere on this web site. I looked, and did not find it. Somewhere in my messed and overcrowded garage, I have a print out, when I find it, I can write it here, if anyone wants it. Randy (Swamp Thing) found it for me back then, but I think he is banned from here, why I do not care to know.
              put something smooooth betwen your legs, XS eleven
              79 F (Blueballs)
              79 SF (Redbutt)
              81 LH (organ donor)
              79 XS 650S (gone to MC heaven)
              76 CB 750 (gone to MC heaven)
              rover has spoken
                • 8962
                I did a similar mod, but I retained the original plunger. I tapped the hole from the front, back to where the side hold down screw is, put a 3/8" bolt in there with RTV on the threads to prevent oil leaking. Now it can be tightened up easily and no chance of the plunger slipping with hard decel.
                • meteor3178
                  • Dec 2006
                  • 22
                  • San Marcos, TX
                  All Yamaha Motorcycles for cam chain tensioner
                  I found this info on a part site. The yamaha part # for the tensioner is 26H-2210-03-00. That part is used on the following bikes.
                  1983 XVZ12TDK CAMSHAFT-CHAIN
                  1984 XVZ1200DL - VENTURE ROYALE CAMSHAFT CHAIN
                  1984 XVZ1200DLC - VENTURE ROYALE CAMSHAFT CHAIN
                  1984 XVZ1200L - VENTURE CAMSHAFT CHAIN
                  1984 XVZ1200LC - VENTURE CAMSHAFT CHAIN
                  1984 XVZ12DKC2 CAMSHAFT - CHAIN
                  1984 XVZ12DL CAMSHAFT - CHAIN
                  1985 VMX1200N - V-MAX CAMSHAFT CHAIN
                  1985 VMX1200NC - V-MAX CAMSHAFT CHAIN
                  1985 VMX12N CAMSHAFT - CHAIN
                  1985 VMX12NC CAMSHAFT - CHAIN
                  1985 XVZ1200DN - VENTURE ROYALE CAMSHAFT CHAIN
                  1985 XVZ12DN CAMSHAFT - CHAIN
                  1986 VMX1200S - V-MAX CAMSHAFT - CHAIN
                  1986 VMX1200SC - V-MAX CAMSHAFT CHAIN
                  1986 XVZ1300DS - VENTURE ROYALE CAMSHAFT - CHAIN
                  1986 XVZ1300DSC - VENTURE ROYALE CAMSHAFT - CHAIN
                  1987 XVZ1300DT - VENTURE ROYALE CAMSHAFT CHAIN
                  1987 XVZ1300DTC - VENTURE ROYALE CAMSHAFT CHAIN
                  1987 XVZ1300T - VENTURE CAMSHAFT CHAIN
                  1987 XVZ1300TC - VENTURE CAMSHAFT CHAIN
                  1987 XVZ13DS CAMSHAFT - CHAIN
                  1987 XVZ13DSC CAMSHAFT - CHAIN
                  1987 XVZ13DT CAMSHAFT - CHAIN
                  1987 XVZ13DTC CAMSHAFT - CHAIN
                  1987 XVZ13T CAMSHAFT - CHAIN
                  1987 XVZ13TC CAMSHAFT - CHAIN
                  1988 VMX1200U - V-MAX CAMSHAFT CHAIN (NON-CALIFORNIA MODEL)
                  1988 VMX1200UC - V-MAX CAMSHAFT CHAIN (CALIFORNIA MODEL ONLY)
                  1988 VMX1200UC - V-MAX CAMSHAFT CHAIN (NON-CALIFORNIA MODEL)
                  1988 VMX12U - V-MAX CAMSHAFT - CHAIN (CALIFORNIA MODEL ONLY)
                  1988 VMX12U - V-MAX CAMSHAFT - CHAIN (NON-CALIFORNIA MODEL)
                  1988 VMX12UC - V-MAX CAMSHAFT - CHAIN (CALIFORNIA MODEL ONLY)
                  1988 VMX12UC - V-MAX CAMSHAFT - CHAIN (NON-CALIFORNIA MODEL)
                  1988 XVZ1300D CAMSHAFT CHAIN
                  1988 XVZ1300DU - VENTURE ROYALE CAMSHAFT CHAIN
                  1988 XVZ1300U - VENTURE CAMSHAFT CHAIN
                  1988 XVZ1300UC - VENTURE CAMSHAFT CHAIN
                  1988 XVZ13DU CAMSHAFT CHAIN
                  1988 XVZ13DUC CAMSHAFT CHAIN
                  1988 XVZ13U CAMSHAFT-CHAIN
                  1988 XVZ13UC CAMSHAFT-CHAIN
                  1989 VMX1200W - V-MAX CAMSHAFT CHAIN CALIFORNIA MODEL ONLY
                  1989 VMX1200W - V-MAX CAMSHAFT CHAIN NON CALIFORNIA MODEL
                  1989 VMX1200WC - V-MAX CAMSHAFT CHAIN CALIFORNIA MODEL ONLY
                  1989 VMX1200WC - V-MAX CAMSHAFT CHAIN NON CALIFORNIA MODEL
                  1989 VMX12W - V-MAX CAMSHAFT CHAIN CALIFORNIA MODEL ONLY
                  1989 VMX12W - V-MAX CAMSHAFT CHAIN NON CALIFORNIA MODEL
                  1989 VMX12WC - V-MAX CAMSHAFT CHAIN CALIFORNIA MODEL ONLY
                  1989 VMX12WC - V-MAX CAMSHAFT CHAIN NON CALIFORNIA MODEL
                  1989 XVZ12DWC CAMSHAFT - CHAIN
                  1989 XVZ1300DW - VENTURE ROYALE CAMSHAFT CHAIN
                  1989 XVZ1300DWC - VENTURE ROYALE CAMSHAFT CHAIN
                  1990 VMX1200A - V-MAX CAMSHAFT CHAIN
                  1990 VMX1200AC - V-MAX CAMSHAFT CHAIN
                  1990 VMX12A - V-MAX CAMSHAFT CHAIN
                  1990 VMX12AC - V-MAX CAMSHAFT CHAIN
                  1990 XVZ1300DA - VENTURE ROYALE CAMSHAFT CHAIN
                  1990 XVZ1300DAC - VENTURE ROYALE CAMSHAFT CHAIN
                  1990 XVZ13DA CAMSHAFT - CHAIN
                  1990 XVZ13DAC CAMSHAFT - CHAIN
                  1991 VMX1200B - V-MAX CAMSHAFT CHAIN
                  1991 VMX1200BC - V-MAX CAMSHAFT CHAIN
                  1991 VMX12B - V-MAX CAMSHAFT CHAIN
                  1991 VMX12BC - V-MAX CAMSHAFT CHAIN
                  1991 XVZ1300DB - VENTURE ROYALE CAMSHAFT CHAIN
                  1991 XVZ1300DBC - VENTURE ROYALE CAMSHAFT CHAIN
                  1991 XVZ13DB CAMSHAFT - CHAIN
                  1991 XVZ13DBC CAMSHAFT - CHAIN
                  1992 VMX1200D - V-MAX CAMSHAFT CHAIN
                  1992 VMX1200DC - V-MAX CAMSHAFT CHAIN
                  1992 VMX12D - V-MAX CAMSHAFT CHAIN
                  1992 VMX12DC - V-MAX CAMSHAFT CHAIN
                  1992 XVZ1300DD - VENTURE ROYALE CAMSHAFT CHAIN
                  1992 XVZ1300DDC - VENTURE ROYALE CAMSHAFT CHAIN
                  1992 XVZ13DDC CAMSHAFT-CHAIN
                  1993 VMX1200E - V-MAX CAMSHAFT CHAIN
                  1993 VMX1200EC - V-MAX CAMSHAFT CHAIN
                  1993 VMX12E - V-MAX CAMSHAFT CHAIN
                  1993 VMX12EC - V-MAX CAMSHAFT CHAIN
                  1993 XVZ1300DE - VENTURE ROYALE CAMSHAFT CHAIN
                  1993 XVZ1300DEC - VENTURE ROYALE CAMSHAFT CHAIN
                  1993 XVZ13DEC CAMSHAFT-CHAIN
                  1994 VMX1200F - V-MAX CAMSHAFT CHAIN
                  1994 VMX1200FC - V-MAX CAMSHAFT CHAIN
                  1994 VMX12F - V-MAX CAMSHAFT CHAIN
                  1994 VMX12FC - V-MAX CAMSHAFT CHAIN
                  1995 VMX1200G - V-MAX CAMSHAFT CHAIN
                  1995 VMX1200GC - V-MAX CAMSHAFT CHAIN
                  1995 VMX12G CAMSHAFT CHAIN
                  1995 VMX12GC CAMSHAFT CHAIN
                  1996 VMX1200H - V-MAX CAMSHAFT CHAIN
                  1996 VMX1200HC - V-MAX CAMSHAFT CHAIN
                  1996 VMX12H - V-MAX CAMSHAFT CHAIN
                  1996 VMX12HC - V-MAX CAMSHAFT CHAIN
                  1996 XVZ1300AH - ROYAL STAR CAMSHAFT CHAIN
                  1996 XVZ1300AHC - ROYAL STAR CAMSHAFT CHAIN
                  1996 XVZ1300ATH - ROYAL STAR TOUR CLASSIC CAMSHAFT CHAIN
                  1996 XVZ1300ATHC - ROYAL STAR TOUR CLASSIC CAMSHAFT CHAIN
                  1996 XVZ13AH CAMSHAFT CHAIN
                  1996 XVZ13AHC CAMSHAFT CHAIN
                  1996 XVZ13ATH CAMSHAFT CHAIN
                  1996 XVZ13ATHC - ROYAL STAR - TOUR CLASSIC (CA Ed.) CAMSHAFT CHAIN
                  1996 XVZ13THC CAMSHAFT CHAIN
                  1997 VMX12J CAMSHAFT CHAIN
                  1997 VMX12JC CAMSHAFT CHAIN
                  1997 XVZ1300AJ - ROYAL STAR CAMSHAFT CHAIN
                  1997 XVZ1300ATJ - ROYAL STAR TOUR CLASSIC CAMSHAFT CHAIN
                  1997 XVZ1300LTJ - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  1997 XVZ1300LTJC - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  1997 XVZ13AJ CAMSHAFT CHAIN
                  1997 XVZ13AJC CAMSHAFT CHAIN
                  1997 XVZ13ATJ CAMSHAFT CHAIN
                  1997 XVZ13ATJC CAMSHAFT CHAIN
                  1997 XVZ13LTJ CAMSHAFT CHAIN
                  1997 XVZ13LTJC CAMSHAFT CHAIN
                  1998 VMX1200K - V-MAX CAMSHAFT CHAIN
                  1998 VMX1200KC - V-MAX CAMSHAFT CHAIN
                  1998 VMX12K - V-MAX CAMSHAFT CHAIN
                  1998 VMX12KC - V-MAX CAMSHAFT CHAIN
                  1998 XV13LTK CAMSHAFT CHAIN
                  1998 XV13LTKC CAMSHAFT CHAIN
                  1998 XVZ1300AK - ROYAL STAR STANDARD CAMSHAFT CHAIN
                  1998 XVZ1300AKC - ROYAL STAR STANDARD CAMSHAFT CHAIN
                  1998 XVZ1300ATK - ROYAL STAR TOUR CLASSIC CAMSHAFT CHAIN
                  1998 XVZ1300ATKC - ROYAL STAR TOUR CLASSIC CAMSHAFT CHAIN
                  1998 XVZ1300LTK - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  1998 XVZ1300LTKC - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  1998 XVZ13AK CAMSHAFT CHAIN
                  1998 XVZ13AKC CAMSHAFT CHAIN
                  1998 XVZ13ATK CAMSHAFT CHAIN
                  1998 XVZ13ATKC CAMSHAFT CHAIN
                  1998 XVZ13LTK CAMSHAFT CHAIN
                  1998 XVZ13LTKC CAMSHAFT CHAIN
                  1998 XVZ13TLKC CAMSHAFT CHAIN
                  1999 VMX1200L - V-MAX CAMSHAFT CHAIN
                  1999 VMX1200LC - V-MAX CAMSHAFT CHAIN
                  1999 VMX12L - V-MAX CAMSHAFT CHAIN
                  1999 VMX12LC - V-MAX CAMSHAFT CHAIN
                  1999 XVZ1300AL - ROYAL STAR BOULEVARD CAMSHAFT CHAIN
                  1999 XVZ1300ALC - ROYAL STAR BOULEVARD CAMSHAFT CHAIN
                  1999 XVZ1300ATL - ROYAL STAR TOUR CLASSIC CAMSHAFT CHAIN
                  1999 XVZ1300ATLC - ROYAL STAR TOUR CLASSIC CAMSHAFT CHAIN
                  1999 XVZ1300LTL - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  1999 XVZ1300LTLC - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  1999 XVZ1300TFL - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  1999 XVZ1300TFLC - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  1999 XVZ13AL CAMSHAFT CHAIN
                  1999 XVZ13ALC CAMSHAFT CHAIN
                  1999 XVZ13ATL - ROYAL STAR TOUR CLASSIC CAMSHAFT CHAIN
                  1999 XVZ13ATLC - ROYAL STAR TOUR CLASSIC (CA Ed.) CAMSHAFT CHAIN
                  1999 XVZ13LTL - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  1999 XVZ13LTLC - ROYAL STAR TOUR DELUXE (CA Ed.) CAMSHAFT CHAIN
                  2000 VMX1200M - V-MAX CAMSHAFT CHAIN
                  2000 VMX1200MC - V-MAX CAMSHAFT CHAIN
                  2000 VMX12M - V-MAX (Yamaha Black) CAMSHAFT CHAIN
                  2000 VMX12MC - V-MAX (Yamaha Black) (CA Ed.) CAMSHAFT CHAIN
                  2000 XVZ1300AM - ROYAL STAR BOULEVARD CAMSHAFT CHAIN
                  2000 XVZ1300AMC - ROYAL STAR BOULEVARD CAMSHAFT CHAIN
                  2000 XVZ1300ATM - ROYAL STAR TOUR CLASSIC CAMSHAFT CHAIN
                  2000 XVZ1300ATMC - ROYAL STAR TOUR CLASSIC CAMSHAFT CHAIN
                  2000 XVZ1300LTM - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  2000 XVZ1300LTMC - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  2000 XVZ1300TFM - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2000 XVZ1300TFMC - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2000 XVZ1300TFSMC - ROYAL STAR VENTURE MM CAMSHAFT CHAIN
                  2000 XVZ13AM - ROYAL STAR (Yamaha Black) CAMSHAFT CHAIN
                  2000 XVZ13AMC - ROYAL STAR (Yamaha Black) (CA Ed.) CAMSHAFT CHAIN
                  2000 XVZ13ATM - ROYAL STAR TOUR CLASSIC CAMSHAFT CHAIN
                  2000 XVZ13ATMC - ROYAL STAR TOUR CLASSIC (CA Ed.) CAMSHAFT CHAIN
                  2000 XVZ13LTM (Yamaha Black) CAMSHAFT CHAIN
                  2000 XVZ13LTMC (Yamaha Black) (CA Ed.) CAMSHAFT CHAIN
                  2000 XVZ13TFM - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2000 XVZ13TFMC - ROYAL STAR VENTURE (CA Ed.) CAMSHAFT CHAIN
                  2000 XVZ13TFSM - VENTURE MM LIMITED EDITION CAMSHAFT CHAIN
                  2000 XVZ13TFSMC - VENTURE MM LIMITED EDITION (CA Ed.) CAMSHAFT CHAIN
                  2001 VMX1200N - V-MAX (New Silver Dust) CAMSHAFT CHAIN
                  2001 VMX1200NC - V-MAX (New Silver Dust) (CA Ed.) CAMSHAFT CHAIN
                  2001 XVZ1300AN - ROYAL STAR BOULEVARD (Yamaha Black) CAMSHAFT CHAIN
                  2001 XVZ1300ANC - ROYAL STAR BOULEVARD (Yamaha Black) ( CAMSHAFT CHAIN
                  2001 XVZ1300LTN - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  2001 XVZ1300LTNC - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  2001 XVZ1300TFN - VENTURE CAMSHAFT CHAIN
                  2001 XVZ13LTN - ROYAL STAR TOUR DELUXE (Yamaha Black) CAMSHAFT CHAIN
                  2001 XVZ13LTNC - ROYAL STAR TOUR DELUXE (Yamaha Black) CAMSHAFT CHAIN
                  2001 XVZ13TFN - VENTURE CAMSHAFT CHAIN
                  2001 XVZ13TFNC - VENTURE (CA Ed.) CAMSHAFT CHAIN
                  2002 VMX1200P - V-MAX CAMSHAFT CHAIN
                  2002 VMX1200PC - V-MAX CAMSHAFT CHAIN
                  2002 VMX12P - V-MAX (New Silver Dust) CAMSHAFT CHAIN
                  2002 VMX12PC - V-MAX (New Silver Dust) CAMSHAFT CHAIN
                  2002 XVZ1300TFP - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2002 XVZ1300TFPC - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2002 XVZ1300TFSP - ROYAL STAR MIDNIGHT VENTURE CAMSHAFT CHAIN
                  2002 XVZ1300TFSPC - ROYAL STAR MIDNIGHT VENTURE CAMSHAFT CHAIN
                  2002 XVZ13TFP - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2002 XVZ13TFPC - ROYAL STAR VENTURE (CA Ed.) CAMSHAFT CHAIN
                  2002 XVZ13TFSP - ROYAL STAR MIDNIGHT VENTURE (Yamaha Bl CAMSHAFT CHAIN
                  2002 XVZ13TFSPC - ROYAL STAR MIDNIGHT VENTURE (Yamaha B CAMSHAFT CHAIN
                  2003 VMX1200R - V-MAX CAMSHAFT CHAIN
                  2003 VMX12R - V-MAX (Matte Black) CAMSHAFT CHAIN
                  2003 VMX12RC - V-MAX (Matte Black) (CA Ed.) CAMSHAFT CHAIN
                  2003 XVZ1300TFR - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2003 XVZ1300TFRC - ROYAL STAR VENTURE (CA Ed.) CAMSHAFT CHAIN
                  2003 XVZ1300TFSR - ROYAL STAR MIDNIGHT VENTURE (Onyx) CAMSHAFT CHAIN
                  2003 XVZ1300TFSRC - ROYAL STAR MIDNIGHT VENTURE (Onyx) CAMSHAFT CHAIN
                  2003 XVZ13TFR CAMSHAFT CHAIN
                  2004 VMX12S1 - V MAX CAMSHAFT CHAIN
                  2004 VMX12SC1 - V MAX CAMSHAFT CHAIN
                  2004 XVZ13TFMS - ROYAL STAR MIDNIGHT VENTURE CAMSHAFT CHAIN
                  2004 XVZ13TFMSC - ROYAL STAR MIDNIGHT VENTURE CAMSHAFT CHAIN
                  2004 XVZ13TFS - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2004 XVZ13TFSC - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2005 VMX12T - V-MAX CAMSHAFT CHAIN
                  2005 VMX12TC - V-MAX CAMSHAFT CHAIN
                  2005 XVZ13CTT - V-STAR 1300 TOURER CAMSHAFT CHAIN
                  2005 XVZ13CTTC - V-STAR 1300 TOURER CAMSHAFT CHAIN
                  2005 XVZ13TFMT - ROYAL STAR MIDNIGHT VENTURE CAMSHAFT CHAIN
                  2005 XVZ13TFMTC - ROYAL STAR MIDNIGHT VENTURE CAMSHAFT CHAIN
                  2005 XVZ13TFT - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2005 XVZ13TFTC - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2006 VMX12V - V-MAX CAMSHAFT CHAIN
                  2006 VMX12VC - V-MAX CAMSHAFT CHAIN
                  2006 XVZ13CTMV - ROYAL STAR MIDNIGHT TOUR DELUXE CAMSHAFT CHAIN
                  2006 XVZ13CTMVC - ROYAL STAR MIDNIGHT TOUR DELUXE CAMSHAFT CHAIN
                  2006 XVZ13CTV - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  2006 XVZ13CTVC - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  2006 XVZ13TFMV - ROYAL STAR MIDNIGHT VENTURE CAMSHAFT CHAIN
                  2006 XVZ13TFMVC - ROYAL STAR MIDNIGHT VENTURE CAMSHAFT CHAIN
                  2006 XVZ13TFV - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2006 XVZ13TFVC - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2007 XVZ13CTMW - ROYAL STAR MIDNIGHT TOUR DELUXE CAMSHAFT CHAIN
                  2007 XVZ13CTMWC - ROYAL STAR MIDNIGHT TOUR DELUXE CAMSHAFT CHAIN
                  2007 XVZ13CTW - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  2007 XVZ13CTWC - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  2007 XVZ13TFMW - ROYAL STAR MIDNIGHT VENTURE CAMSHAFT CHAIN
                  2007 XVZ13TFMWC - ROYAL STAR MIDNIGHT VENTURE CAMSHAFT CHAIN
                  2007 XVZ13TFW - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2007 XVZ13TFWC - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2008 XVZ13CTSX - ROYAL STAR TOUR DELUXE S CAMSHAFT CHAIN
                  2008 XVZ13CTSXC - ROYAL STAR TOUR DELUXE S CAMSHAFT CHAIN
                  2008 XVZ13CTX - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  2008 XVZ13CTXC - ROYAL STAR TOUR DELUXE CAMSHAFT CHAIN
                  2008 XVZ13TFSX - ROYAL STAR VENTURE S CAMSHAFT CHAIN
                  2008 XVZ13TFSXC - ROYAL STAR VENTURE S CAMSHAFT CHAIN
                  2008 XVZ13TFX - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2008 XVZ13TFXC - ROYAL STAR VENTURE CAMSHAFT CHAIN
                  2009 XVZ13CTSY - ROYAL STAR TOUR DELUXE S (Dark Bluish CAMSHAFT CHAIN
                  2009 XVZ13CTSYC - ROYAL STAR TOUR DELUXE S (Dark Bluish CAMSHAFT CHAIN
                  2009 XVZ13CTYCR - ROYAL STAR TOUR DELUXE (Dark Red Meta CAMSHAFT CHAIN
                  2009 XVZ13CTYR - ROYAL STAR TOUR DELUXE (Dark Red Metal CAMSHAFT CHAIN
                  2009 XVZ13TFSY - ROYAL STAR VENTURE S (Light Yellowish CAMSHAFT CHAIN
                  2009 XVZ13TFSYC - ROYAL STAR VENTURE S (Light Yellowish CAMSHAFT CHAIN
                  2009 XVZ13TFYCR - ROYAL STAR VENTURE (Deep Red Metallic CAMSHAFT CHAIN
                  2009 XVZ13TFYR - ROYAL STAR VENTURE (Deep Red Metallic CAMSHAFT CHAIN
                  HTH
                  Meteor3178
                  1980 XS1100SG
                  My mods:
                  Takt fork brace
                  Goldwing handlebars
                  Progressive fork springs & shocks
                  Blade fuses and fuseholder
                  850 Final drive
                  Vetter Trunk
                  "the meteor lit up the highways"
                  • DAVINCI
                    • Jan 2011
                    • 1048
                    • Cedar Mountain, NC
                    A quick check on Bike Bandit didn't show that part#, but did show this:
                    26H-12210-01-00
                    Fits:
                    1983 Yamaha VENTURE - XVZ12TK View schematics
                    1983 Yamaha VENTURE ROYALE - XVZ12TDK View schematics
                    1985 Yamaha VENTURE ROYALE - XVZ12DN View schematics
                    1985 Yamaha VMX1200N V-MAX View schematics
                    1985 Yamaha VMX1200NC V-MAX View schematics
                    1986 Yamaha VENTURE ROYALE - XVZ13DS View schematics
                    1986 Yamaha VENTURE ROYALE - XVZ13DSC(California Model) View schematics
                    1986 Yamaha VMAX - VMX1200S View schematics
                    1986 Yamaha VMAX - VMX1200SC(California Model) View schematics
                    1987 Yamaha VENTURE - XVZ13T View schematics
                    1987 Yamaha VENTURE - XVZ13T(California Model) View schematics
                    1987 Yamaha VENTURE ROYALE - XVZ13DT View schematics
                    1987 Yamaha VENTURE ROYALE - XVZ13DT(California Model) View schematics
                    1988 Yamaha VENTURE - XVZ13U View schematics
                    1988 Yamaha VENTURE - XVZ13UC(CAL MODEL) View schematics
                    1988 Yamaha VENTURE ROYALE - XVZ13DU View schematics
                    1988 Yamaha VENTURE ROYALE - XVZ13DUC(CAL MODEL) View schematics
                    1988 Yamaha V-MAX - VMX12U View schematics
                    1988 Yamaha V-MAX - VMX12UC(CAL MODEL) View schematics
                    1988 Yamaha XVZ1300D View schematics
                    1989 Yamaha VENTURE ROYALE - XVZ1300DW View schematics
                    1989 Yamaha VENTURE ROYALE - XVZ1300DWC(CAL MODEL) View schematics
                    1989 Yamaha V-MAX - VMX12W View schematics
                    1989 Yamaha V-MAX - VMX12WC(CAL MODEL) View schematics
                    1990 Yamaha VENTURE ROYALE - XVZ13DA View schematics
                    1990 Yamaha VENTURE ROYALE - XVZ13DAC(CAL MODEL) View schematics
                    1990 Yamaha VMAX - VMX12A View schematics
                    1990 Yamaha VMAX - VMX12AC(CAL MODEL) View schematics
                    1991 Yamaha VENTURE ROYALE - XVZ13DB View schematics
                    1991 Yamaha VENTURE ROYALE - XVZ13DBC(CAL MODEL) View schematics
                    1991 Yamaha VMAX / VMX12B View schematics
                    1991 Yamaha VMAX / VMX12BC(CAL MODEL) View schematics
                    1992 Yamaha VENTURE ROYALE - XVZ13DD View schematics
                    1992 Yamaha VENTURE ROYALE - XVZ13DDC(CAL MODEL) View schematics
                    1992 Yamaha VMAX / VMX12D View schematics
                    1992 Yamaha VMAX / VMX12DC(CAL MODEL) View schematics
                    1993 Yamaha VENTURE ROYALE - XVZ13DE View schematics
                    1993 Yamaha VENTURE ROYALE - XVZ13DEC(CAL MODEL) View schematics
                    1993 Yamaha V-MAX / VMX12E View schematics
                    1993 Yamaha V-MAX / VMX12EC(CAL MODEL) View schematics
                    1994 Yamaha V-MAX / VMX12F View schematics
                    1994 Yamaha V-MAX / VMX12FC(CAL MODEL) View schematics
                    1995 Yamaha V-MAX / VMX12G View schematics
                    1995 Yamaha V-MAX / VMX12GC(CAL MODEL) View schematics
                    1996 Yamaha ROYAL STAR STANDARD / XVZ13AH View schematics
                    1996 Yamaha ROYAL STAR STANDARD / XVZ13AHC(CAL MODELS) View schematics
                    1996 Yamaha ROYAL STAR TOUR CLASSIC / XVZ13ATH View schematics
                    1996 Yamaha ROYAL STAR TOUR CLASSIC / XVZ13ATHC(CAL MODEL) View schematics
                    1996 Yamaha V-MAX / VMX2H View schematics
                    1996 Yamaha V-MAX / VMX2HC(CAL MODEL) View schematics
                    1997 Yamaha ROYAL STAR - XVZ13AJ View schematics
                    1997 Yamaha ROYAL STAR - XVZ13AJC(CAL MODEL) View schematics
                    1997 Yamaha ROYAL STAR TOUR CLASSIC - XVZ13ATJ View schematics
                    1997 Yamaha ROYAL STAR TOUR CLASSIC - XVZ13ATJC(CAL MODEL) View schematics
                    1997 Yamaha ROYAL STAR TOUR DELUXE - XVZ13LTJ View schematics
                    1997 Yamaha ROYAL STAR TOUR DELUXE - XVZ13LTJC(CAL MODEL) View schematics
                    1997 Yamaha V-MAX / VMX12J View schematics
                    1997 Yamaha V-MAX / VMX12JC(CAL MODEL) View schematics
                    1997 Yamaha VMX12J View schematics
                    1998 Yamaha ROYAL STAR STANDARD - XVZ13AKC(CAL MODEL) View schematics
                    1998 Yamaha ROYAL STAR STANDARD- XVZ13AK View schematics
                    1998 Yamaha ROYAL STAR TOUR CLASSIC - XVZ13ATK View schematics
                    1998 Yamaha ROYAL STAR TOUR CLASSIC - XVZ13ATKC(CAL MODEL) View schematics
                    1998 Yamaha ROYAL STAR TOUR DELUXE - XVZ13LTK View schematics
                    1998 Yamaha ROYAL STAR TOUR DELUXE - XVZ13LTKC(CAL MODEL) View schematics
                    1998 Yamaha V-MAX / VMX12K View schematics
                    1998 Yamaha V-MAX / VMX12KC(CAL MODEL) View schematics
                    1999 Yamaha ROYAL STAR / XVZ13AL View schematics
                    1999 Yamaha ROYAL STAR / XVZ13ALC(CAR MODEL) View schematics
                    1999 Yamaha ROYAL STAR TOUR CLASSIC / XVZ13ATL View schematics
                    1999 Yamaha ROYAL STAR TOUR CLASSIC / XVZ13ATLC(CAL MODEL) View schematics
                    1999 Yamaha ROYAL STAR TOUR DELUXE - XVZ13LTL View schematics
                    1999 Yamaha ROYAL STAR TOUR DELUXE - XVZ13LTLC(CAL MODEL) View schematics
                    1999 Yamaha ROYAL STAR VENTURE / XVZ13TFL View schematics
                    1999 Yamaha ROYAL STAR VENTURE / XVZ13TFLC(CAL MODEL) View schematics
                    1999 Yamaha V-MAX / VMX12L View schematics
                    1999 Yamaha V-MAX / VMX12LC(CAL MODEL) View schematics
                    2000 Yamaha ROYAL STAR / XVZ13AM View schematics
                    2000 Yamaha ROYAL STAR / XVZ13AMC(CAL MODEL) View schematics
                    2000 Yamaha ROYAL STAR TOUR CLASSIC / XVZ13ATM View schematics
                    2000 Yamaha ROYAL STAR TOUR CLASSIC / XVZ13ATMC(CAL MODEL) View schematics
                    2000 Yamaha ROYAL STAR TOUR DELUXE - XVZ13LTM View schematics
                    2000 Yamaha ROYAL STAR TOUR DELUXE - XVZ13LTMC(CAL MODEL) View schematics
                    2000 Yamaha ROYAL STAR VENTURE / XVZ13TFM View schematics
                    2000 Yamaha ROYAL STAR VENTURE / XVZ13TFMC(CAL MODEL) View schematics
                    2000 Yamaha VENTURE MM LIMITED EDITION / XVZ13TFSM View schematics
                    2000 Yamaha VENTURE MM LIMITED EDITION / XVZ13TFSMC(CAL MODEL) View schematics
                    2000 Yamaha V-MAX / VMX12M View schematics
                    2000 Yamaha V-MAX / VMX12MC(CAL MODEL) View schematics
                    2000 Yamaha XVZ1300TFSM ROYAL STAR VENTURE MM View schematics
                    2000 Yamaha XVZ1300TFSMC ROYAL STAR VENTURE MM View schematics
                    2001 Yamaha VENTURE / XVZ13TFN View schematics
                    2001 Yamaha VENTURE / XVZ13TFNC(CAL MODEL) View schematics
                    2001 Yamaha V-MAX / VMX12N View schematics
                    2001 Yamaha V-MAX / VMX12NC(CAL MODEL) View schematics
                    2001 Yamaha XVZ1300AN ROYAL STAR BOULEVARD View schematics
                    2001 Yamaha XVZ1300ANC ROYAL STAR BOULEVARD View schematics
                    2001 Yamaha XVZ1300LTN ROYAL STAR TOUR DELUXE View schematics
                    2001 Yamaha XVZ1300LTNC ROYAL STAR TOUR DELUXE View schematics
                    2002 Yamaha VMX1200P V-MAX View schematics
                    2002 Yamaha VMX1200PC V-MAX(CAL MODEL) View schematics
                    2002 Yamaha XVZ1300TFP ROYAL STAR VENTURE View schematics
                    2002 Yamaha XVZ1300TFPC ROYAL STAR VENTURE(CAL MODEL) View schematics
                    2002 Yamaha XVZ1300TFSP ROYAL STAR MIDNIGHT VENTURE View schematics
                    2002 Yamaha XVZ1300TFSPC ROYAL STAR MIDNIGHT VENTURE(CAL MODEL) View schematics
                    2003 Yamaha VMX1200R V-MAX View schematics
                    2003 Yamaha VMX1200RC V-MAX View schematics
                    2003 Yamaha XVZ1300TFR ROYAL STAR VENTURE View schematics
                    2003 Yamaha XVZ1300TFRC ROYAL STAR VENTURE (CAL MODEL) View schematics
                    2003 Yamaha XVZ1300TFSR ROYAL STAR MIDNIGHT VENTURE View schematics
                    2003 Yamaha XVZ1300TFSR ROYAL STAR MIDNIGHT VENTURE (CAL MODEL) View schematics
                    2004 Yamaha VMX12S1 V MAX View schematics
                    2004 Yamaha VMX12SC1 V MAX (CAL MODEL) View schematics
                    2004 Yamaha XVZ13TFMS ROYAL STAR MIDNIGHT VENTURE View schematics
                    2004 Yamaha XVZ13TFMSC ROYAL STAR MIDNIGHT VENTURE (CAL MODEL) View schematics
                    2004 Yamaha XVZ13TFS ROYAL STAR VENTURE View schematics
                    2004 Yamaha XVZ13TFSC ROYAL STAR VENTURE (CAL MODEL) View schematics
                    2005 Yamaha VMX12T V-MAX View schematics
                    2005 Yamaha VMX12TC V-MAX (CAL MODEL) View schematics
                    2005 Yamaha XVZ13CTT ROYAL STAR TOUR DELUXE View schematics
                    2005 Yamaha XVZ13CTTC View schematics
                    2005 Yamaha XVZ13TFMT ROYAL STAR MIDNIGHT VENTURE View schematics
                    2005 Yamaha XVZ13TFMTC ROYAL STAR MIDNIGHT VENTURE View schematics
                    2005 Yamaha XVZ13TFT ROYAL STAR VENTURE View schematics
                    2005 Yamaha XVZ13TFTC ROYAL STAR VENTURE View schematics
                    2006 Yamaha VMX12V V-MAX View schematics
                    2006 Yamaha VMX12VC V-MAX View schematics
                    2006 Yamaha XVZ13CTMV ROYAL STAR MIDNIGHT TOUR DELUXE View schematics
                    2006 Yamaha XVZ13CTMVC ROYAL STAR MIDNIGHT TOUR DELUXE View schematics
                    2006 Yamaha XVZ13CTV ROYAL STAR TOUR DELUXE View schematics
                    2006 Yamaha XVZ13CTVC ROYAL STAR TOUR DELUXE View schematics
                    2006 Yamaha XVZ13TFMV ROYAL STAR MIDNIGHT VENTURE View schematics
                    2006 Yamaha XVZ13TFMVC ROYAL STAR MIDNIGHT VENTURE View schematics
                    2006 Yamaha XVZ13TFV ROYAL STAR VENTURE View schematics
                    2006 Yamaha XVZ13TFVC ROYAL STAR VENTURE View schematics
                    2007 Yamaha VMX12W1 V MAX View schematics
                    2007 Yamaha VMX12W1C V MAX View schematics
                    2007 Yamaha XVZ13CTMW View schematics
                    2007 Yamaha XVZ13CTMWC View schematics
                    2007 Yamaha XVZ13CTW View schematics
                    2007 Yamaha XVZ13CTWC View schematics
                    2007 Yamaha XVZ13CTWMC View schematics
                    2007 Yamaha XVZ13TFMW ROYAL STAR MIDNIGHT VENTURE View schematics
                    2007 Yamaha XVZ13TFMWC ROYAL STAR MIDNIGHT VENTURE View schematics
                    2007 Yamaha XVZ13TFW ROYAL STAR VENTURE View schematics
                    2007 Yamaha XVZ13TFWC ROYAL STAR VENTURE View schematics
                    2008 Yamaha XVZ13CT ROYAL STAR TOUR DELUXE View schematics
                    2008 Yamaha XVZ13CTC ROYAL STAR TOUR DELUXE View schematics
                    2008 Yamaha XVZ13CTS ROYAL STAR TOUR DELUXE S View schematics
                    2008 Yamaha XVZ13CTSC ROYAL STAR TOUR DELUXE S View schematics
                    2008 Yamaha XVZ13TF ROYAL STAR VENTURE View schematics
                    2008 Yamaha XVZ13TFC ROYAL STAR VENTURE View schematics
                    2008 Yamaha XVZ13TFS ROYAL STAR VENTURE S View schematics
                    2008 Yamaha XVZ13TFSC ROYAL STAR VENTURE S View schematics
                    2009 Yamaha ROYAL STAR TOUR DELUXE (Dark Red Metallic K) - XVZ View schematics
                    2009 Yamaha ROYAL STAR TOUR DELUXE (Dark Red Metallic K) (CA E View schematics
                    2009 Yamaha ROYAL STAR TOUR DELUXE S (Dark Bluish Gray Metalli View schematics
                    2009 Yamaha ROYAL STAR VENTURE (Deep Red Metallic K / Black Me View schematics
                    2009 Yamaha ROYAL STAR VENTURE S (Light Yellowish Gray Metalli View schematics
                    2010 Yamaha ROYAL STAR TOUR DELUXE S - XVZ13CTSZ View schematics
                    2010 Yamaha ROYAL STAR TOUR DELUXE S - XVZ13CTSZC View schematics
                    2010 Yamaha ROYAL STAR VENTURE S - XVZ13TFSZ View schematics
                      Jeez after 27 years you'd think there is room for improvement
                      • tinman905
                        • Aug 2007
                        • 946
                        • Orangeville,Ontario ,Canada
                        We like you just the way you are Phil Wow that's one heck of a list of bikes for one part.
                        BDF Special
