Special carbs on a Standard?
  • newmaac
    • Dec 2002
    • 369
    • San Jose, CA
    After trying the "push pin trick" and the "mechanic's probe trick" I still have a broken Pilot screw in one of the carbs on an F that I am restoring. Tomorrow, I am going to try using a little heat to see if it will budge. If that doesn't work, I am probably going to abandon that carb and move on.
    I have other banks of carbs to pick from.
    My options:
    1) Replace just that one carb body with one taken from a rack that has 3 good carbs, and one with a broken float post. I am a little leary of disassembling the bank and messing with the T's.
    Or
    2) Replace the whole bank with one from an 80 Special, or an 81 Midnight.
    How much trouble is it to change from the Special? I know that the vacuum and fuel lines are differant.
    Also, If I DO get the broken pin out, I will need a new set if Pilot screws. Motorcyclecarbs.com sells them for about $66 for the 4 screws with shipping and tax. That seems high. Has anyone found a better source?
    TIA
    Mike
    1980 SG "Angus"
  • Jeff
    • Apr 2003
    • 263
    • Pocatello, Idaho
    Last I checked... the pilot screws were still available from Yamaha ..... at least thru Power Sports Pro online... for about $8 each.
    1978 XS1100E "Flashback"
    "If at first you don't succeed.... Get a bigger hammer."
      Hey there NewMaac,
      The "T's" are just held in place with rubber O-ring gaskets. But if you decide to use the 80-81 carbs, then you just have to plug the vent lines that come off the tops of the older carbs, and then just hook the supply lines to the lower "T's" from your petcocks. The Specials have that fancy plumbing with the octopus, but since you don't have one on your "F", then it's a direct connect! Good luck with the heat technique.
      • newmaac
        • Dec 2002
        • 369
        • San Jose, CA
        The heat worked!!
        When I have a few minutes, I will post an addendum to the tech tips on repairing the broken needles.
        Mike
        Mike
        1980 SG "Angus"
        • puttman
          • Jul 2003
          • 41
          • Garland, TX
          e-bay has carb kits 4 for $65 with all the parts
          THESE KITS COME WITH ALL GASKETS AND O-RINGS, IDLE MIXTURE SCREW, MAIN AND PILOTS JETS, FLOAT NEEDLE AND SEAT ASSEMBLY
          e-bay # 2438577552
          my bid is $62 hope ya dont jack me up, there are and will be more available,
          WATCH OUT for one kit That only has like 6 peices in it.
          hope this helps as I have two banks and three bad carbs and plan on fixing #1 has a broken float post and the other has a broken pilot jet with a broken e z out in it, I will have to trash that one. LOL
          Charlie
          Rockwall, TX
